Group: DynoMotion Message: 3079 From: albertplatek Date: 1/12/2012
Subject: Coord buffer overflow again
1. Why on 1 pc kmotioncnc works ok, but on second not, with same settings?
(collinear tollerance 1)
same file, same accelerations etc.
on second I have only usb 3.0 ports.
2. How much data come to Gviewer from kflop? if a lot is it possible
to bypass this if I dont need to use G viewer?
I make a lot of reliefs in wood, with kinda high acceleleration 40, if
will be any way to get more performance from kflop with smoothing feature will be very good.
Best Regards
Albert P³atek
Group: DynoMotion Message: 3088 From: Tom Kerekes Date: 1/12/2012
Subject: Re: Coord buffer overflow again
Hi Albert,
Could you send me the Gcode and all your settings?  I don't understand the collinear tolerance of 1?  That seems huge.  Did you mean 0.001?
A corner rounding facet angle too small might be generating too many small segments.  Are you using the Coordinated Motion Low Pass Filter Smoothing option?  That might help make as smooth or smoother motion with larger facets.
The USB throughput can vary from one machine to the other.
No data for the GViewer comes from KFLOP it all comes from the trajectory planner on the PC.
Group: DynoMotion Message: 3097 From: albertplatek Date: 1/12/2012
My settings:
Break angle 30
Look ahead 3
Collinear tolerance 0.001
Corner tolerance 0.005
Facet angle 2.0 (if I go to 1.5, i get cord buffer overflow almost from program start)
I use Tau = 0.01; (with facet angle 2.0 machine movements are fairly smooth)
All 3 axis has same Vel/Accel parameters:
Vel 5.0
Accel 40
Toolpath is parallel along X-axis (contain a lot of small arcs, I will send file tomorrow)
With this settings my first router with old laptop works ok (Dell, core 2 duo, ati graphics card),
but on second router (same settings) with new laptop dont work, i often get buffer overflows. (laptop Dell, i7 cpu, Win7 64bit, Nvidia Gt555)
(Btw. when GViewer is open and I move view by mouse path generation slows down, is it normal?)
Best Regards
Albert P³atek
> Hi Albert,
> From: albertplatek <albertplatek86@...>
> Sent: Thursday, January 12, 2012 11:11 AM
> Subject: [DynoMotion] Coord buffer overflow again
> Hi Tom,
> Best Regards
> Albert P³atek
Group: DynoMotion Message: 3098 From: Tom Kerekes Date: 1/12/2012
Hi Albert,
Yes please send the file.  Is the feedrate set high 300ipm?
What do you mean by "path generation slows down"?
Group: DynoMotion Message: 3101 From: Albert Płatek Date: 1/13/2012
Attachments :
GCode file is attached with this message.
Yes feedrate is 300ipm.
What do you mean by "path generation slows down"? - i mean that when I am changing view perspective in GViewer
the "simulated tool" catching up end of buffered path. So thats why I thought  that maybe gviewer impact on performance somehow.
Best Regards
Albert Płatek
2012/1/13 Tom Kerekes <tk@...>
Hi Albert,
Sent: Thursday, January 12, 2012 3:35 PM
Subject: [DynoMotion] Re: Coord buffer overflow again
My settings:
Break angle 30
Look ahead 3
Vel 5.0
Accel 40
Best Regards
Albert P³atek
> Hi Albert,
> Hi Tom,
> Best Regards
> Albert P³atek
  @@attachment@@
Group: DynoMotion Message: 3117 From: albertplatek Date: 1/14/2012
How to determine USB throughput on pc? or what pc/system is best for KFlop?
I have still sometimes cord buffer overflow on second pc even I
set lower accelaration 25 and bigger facet angle 2.5 it sometimes
overflow. Its very strange pc has windows xp clean installation,
Integrated Intel Graphics.
On first pc works perfect even with high acceleration 40, facet angle 2.0 (also windows xp, but ati graphics)
Break angle 30
Look ahead 3
Vel 5
Best Regards
Albert Platek
--- In DynoMotion@yahoogroups.com, Albert P³atek <albertplatek86@...> wrote:
> Hi Tom,
> Best Regards
> Albert Płatek
> > Hi Albert,
> > Thanks
> > *From:* albertplatek <albertplatek86@...>
> > *To:* DynoMotion@yahoogroups.com
> > *Sent:* Thursday, January 12, 2012 3:35 PM
> > *Subject:* [DynoMotion] Re: Coord buffer overflow again
> > Hi Tom,
> > My settings:
> > Break angle 30
> > Look ahead 3
> > program start)
> > smooth)
> > Vel 5.0
> > Accel 40
> > send file tomorrow)
> > Best Regards
> > Albert P³atek
> > --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@> wrote:
> > > Hi Albert,
> > > Â
> > > Â
> > larger facets.
> > > Â
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Â
> > > From: albertplatek <albertplatek86@>
> > > Â
> > > Hi Tom,
> > settings?
> > > Best Regards
> > > Albert P³atek
Group: DynoMotion Message: 3121 From: Tom Kerekes Date: 1/14/2012
Hi Albert,
Your application/system is quite demanding :}
That portion of GCode you sent is 100,000 lines of all G1 movements with typical tiny lengths of only 50~150um.  The collinear tolerance of 0.001 (25um) will cause many blocks to be combined together so the real required vector rate will be more dependent on the path curvature rather than the original GCode.
On my system (i7 W7 32-bit) it runs ok with a facet angle 0f 0.4 degrees but can't keep up at 0.3 degrees.
I did some calculations for a system like yours with 40 in/sec2 acceleration.  Here is what I find:
That acceleration allows going around a 0.1 inch radius circle at 120ipm (which is about 3 circles per second)
With a facet angle setting of 1.5 degrees that requires 240 segments per circle which would require 720 segments per second
I created a diagnostic test GCode file that programmatically generates an N sided Polygon 100 times with radius 0.1 inches and allows you to specify the number of polygon sides (it also gradually shifts the "circle" to make the plot more interesting).  (see attachment).  When using the diagnostic make sure to set the Collinear tolerance to zero and the Corner Rounding to zero so the original segments are used.  By changing N (number of sides we can determine the segment download rate).
For example on my system it works with N = 200 and fails with N = 240.  The total time to do all 100 circles takes about 30 seconds.  So:
100 circles x 200 segments/circle / 30 seconds = 666 segments per second.
In simulation mode the Interpreter+Graphics finishes the job in ~ 5 seconds so it isn't a significant factor
With the GCode Window closed it simulates in ~ 4 seconds so the Graphical Display is not a significant factor.
You might run the tests on your two systems to see if you get drastically different results.
But to try to answer your original question of why one CPU would be significantly different I don't know.  Google finds some benchmarking tools but they are mainly for High Speed USB devices like flash drives.  Some sites state if an older USB 1.1 device is attached it slows everything down.
Group: DynoMotion Message: 3122 From: albertplatek Date: 1/15/2012
First thank you Tom for the test file.
I made few tests and I got interesting results :)
PC No1:
Intel Pentium 4 2.6Ghz WinXP 32bit port USB2.0
Max segments: 110
Time: 31s
100 circles x 110 segments/circle / 31 seconds = 354 segments per second.
PC No2:
Intel Core2Duo 2.0 Ghz WinXP 32bit port USB2.0
Max segments: 140
Time: 31s
100 circles x 140 segments/circle / 31 seconds = 451 segments per second.
PC No3:
i7 2670QM Win7 64bit port USB3.0
Max segments:30
Time:31s
100 circles x 60 segments/circle / 31 seconds = 193 segments per second.
(thats why I had problem here, usb 3.0 fail)
(Luckily I had 1 USB 2.0 port)
i7 2670QM Win7 64bit port USB2.0
Max segments:170
Time:31s
100 circles x 170 segments/circle / 31 seconds = 548 segments per second.
i7 2670QM Win7 64bit port USB2.0 (with 1 core affinity for KmotionCNC and KmotionServer)
Max segments:200
Time:31s
100 circles x 200 segments/circle / 31 seconds = 645 segments per second.
I found on net some interesting software called Fidelizer, its software to optimize win7/vista for audio workstation, but it aslo tweak somehow usb throughput.
More detail here: /www.windowsxlive.net/fidelizer
i7 2670QM Win7 64bit port USB2.0 (Fidelizer)
Max segments:410
Time:31s
100 circles x 410 segments/circle / 31 seconds = 1320 segments per second. (wow! tested few times with same result)
Be aware of new USB 3.0 ports they may not work with good performance with KFlop, maybe becouse of bug in drivers. Windows 7 dont see them without additional drivers.
Fidelizer software only improved performance on pc with  Win7.
On WinXP seem to not work. I will soon try install on "PC No2" Windows 7 and then try fidelizer also.
Best regards
Albert P³atek
> Hi Albert,
> From: albertplatek albertplatek86@...
> Sent: Saturday, January 14, 2012 11:02 AM
> Hi Tom,
> Break angle 30
> Look ahead 3
> Vel 5
> Best Regards
> Albert Platek
> --- In DynoMotion@yahoogroups.com, Albert P³atek albertplatek86@ wrote:
> > Hi Tom,
> > Best Regards
> > Albert PÅ‚atek
> > 2012/1/13 Tom Kerekes tk@
> > > Hi Albert,
> > > Thanks
> > > *From:* albertplatek albertplatek86@
> > > Hi Tom,
> > > My settings:
> > > Break angle 30
> > > Look ahead 3
> > > program start)
> > > smooth)
> > > Vel 5.0
> > > Accel 40
> > > send file tomorrow)
> > > Best Regards
> > > Albert P³atek
> > > > Hi Albert,
> > > > Â
> > > > Â
> > > larger facets.
> > > > Â
> > > > Â
> > > > Â
> > > > Regards
> > > > TK
> > > > Â
> > > > Â
> > > > Â
> > > > Hi Tom,
> > > settings?
> > > > Best Regards
> > > > Albert P³atek
Group: DynoMotion Message: 3136 From: Tom Kerekes Date: 1/16/2012
Hi Albert,
Thanks for that interesting information.
I tried the Fidelizer on my i7 W7 32 machine and it didn't seem to make any difference.
I'm trying some things to increase the segment rate by sending blocks of segments and optimizing how they are handled in KFLOP.  If this bears fruit I'll let you know.
This diagnostic pointed out a side problem I hadn't noticed before.  There is an annoying ~30 second delay when it runs the second time.  The Interpreter keeps a record of all its state changes which allow Halts to go back to any previous state.  In this test of 100x500 subroutine calls results in about 1 million state changes.  Ironically creating the data, making use of the data all happens in the blink of an eye, but discarding the data (CList.RemoveAll) takes 30 seconds!  We will find a better way in the next version.  For now just don't be surprised  if there is an annoying delay on a second run of a big job.
Group: DynoMotion Message: 3142 From: albertplatek Date: 1/16/2012
Thank you for making changes in new version to increase the segment rate.
Btw:
I installed on second pc Windows 7 (Core2Duo cpu), and aslo tested with fidelizer. Strange but didn't make difference, as in your computer.
I cant get why in this particular case (pc with WIN7 i7 cpu) it helps.
Maybe it depends on type of host controller...
Pc with WIN7 64bit (Core2Duo) has
SiS 7001 PCI to USB Open Host Controller
Pc with WIN7 64bit (i7) has
Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller
This computer has aslo another usb ports: Renesas Electronics USB 3.0 Host Controller
which works very bad with KFlop. And on this port fidelizer make no difference.
Best Regards
Albert Platek
> Hi Albert,
> Sent: Sunday, January 15, 2012 8:37 AM
> Hi Tom,
> PC No1:
> Max segments: 110
> Time: 31s
> 100 circles x 110 segments/circle / 31 seconds =354 segments per second.
> PC No2:
> Max segments: 140
> Time: 31s
> PC No3:
> Max segments:30
> Time:31s
> Max segments:170
> Time:31s
> Max segments:200
> Time:31s
> 100 circles x 200 segments/circle / 31 seconds =645 segments per second.
> Max segments:410
> Time:31s
> Best regards
> Albert P³atek
> > Hi Albert,
> > Hi Tom,
> > Break angle 30
> > Look ahead 3
> > Vel 5
> > Best Regards
> > Albert Platek
> > > Hi Tom,
> > > Best Regards
> > > Albert PÅ‚atek
> > > > Hi Albert,
> > > > Thanks
> > > > TK
> > > > Hi Tom,
> > > > My settings:
> > > > Break angle 30
> > > > Look ahead 3
> > > > program start)
> > > > smooth)
> > > > Vel 5.0
> > > > Accel 40
> > > > send file tomorrow)
> > > > Best Regards
> > > > Albert P³atek
> > > > > Hi Albert,
> > > > > ÃÆ'‚
> > > > > Could you send me the Gcode and all your settings?ÃÆ'‚ I don't understand
> > > > the collinear tolerance of 1?ÃÆ'‚ That seems huge.ÃÆ'‚ Did you mean 0.001?
> > > > > ÃÆ'‚
> > > > small segments.ÃÆ'‚ Are you using the Coordinated Motion Low Pass Filter
> > > > Smoothing option?ÃÆ'‚ That might help make as smooth or smoother motion with
> > > > larger facets.
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > ÃÆ'‚
> > > > > Hi Tom,
> > > > settings?
> > > > > Best Regards
> > > > > Albert PÃÆ'‚³atek
Group: DynoMotion Message: 3143 From: Tom Kerekes Date: 1/16/2012
Hi Albert,
Thanks for the additional info.
BTW for the the 1320 facets per second (there are actually 2 segments downloaded per facet.  Segments vary in size but are ~100 bytes each), so that comes out to:
1320 x 2 x 100 = 264 KBytes/second which is 21% of max theoretical 1.25MByes/sec USB Full speed.
Group: DynoMotion Message: 3171 From: Tom Kerekes Date: 1/18/2012
Hi Albert,
Just wanted to mention that I now do notice an improvement with Fidelizer.  I don't understand why I didn't before. I might have made a mistake or something changed.
I sent an email to FTDI (USB chip we use) regarding it and the USB 3.0 port issue to see if they have any answers.  I figure it is worth the cost of an email :}
Still working on some optimization...
Group: DynoMotion Message: 3206 From: Albert Date: 1/19/2012
Thank you.
Btw. I am trying to find out what changes make
Fidelizer in Windows. If I will find something
important I will let you know.
Best regards
Albert Platek
Dnia 2012-01-18 o godz. 23:47 Tom Kerekes <tk@...> napisał(a):
Hi Albert,
Group: DynoMotion Message: 3721 From: albertplatek Date: 2/5/2012
My settings:
Break angle 30 deg
Look ahead 3 sec
Collinear tolerance 0.001 in
Corner tolerance 0.003 in
Facet angle 1.5 deg
Tau = 0.008 sec
XYZ Accelarations 40 in/sec2
XYZ Velocity 4.5 in/sec
In gcode file I use max Vel 270 in/min (4.5 in/sec)
I have strange problem, everything was ok until I started machining
bigger reliefs.
At half of the job my stepper motors lost position
probably becouse of high jerk of acceleration.
Firstly I thought that maybe axis accelerations for my system are to high(40in/sec2). So I changed it to 20in/sec2 for test.
But didnt help, still stepper motors stall at half of the gcode file.
This file contain 548389 lines, my steppers stall between 226000 - 274000 line but not always in same place.
I tried to find line where the problem occurs, but when I found line with problem and tried to execute 500 lines before, it was ok. Motors didnt stall.
I found that motors stall when KMotionCNC start execute at least
100 000 lines before line number 274000.
The problem disappear when I set break angle 5deg.
"This diagnostic pointed out a side problem I hadn't noticed before. There is an annoying ~30 second delay when it runs the second time. The Interpreter keeps a record of all its state changes which allow Halts to go back to any previous state. In this test of 100x500 subroutine calls results in about 1 million state changes. Ironically creating the data, making use of the data all happens in the blink of an eye, but discarding the data (CList.RemoveAll) takes 30 seconds! We will find a better way in the next version. For now just don't be surprised if there is an annoying delay on a second run of a big job."
Can this "delay" make that my stepper motors stall?
Best Regards
Albert P³atek
--- In DynoMotion@yahoogroups.com, Albert <albertplatek86@...> wrote:
> Hi Tom,
> Thank you.
> Best regards
> Albert Platek
> (a):
> > Hi Albert,
> > Sent: Monday, January 16, 2012 12:01 PM
> > Hi Tom,
> > rate.
> > Btw:
> > computer.
> > Controller
> > 3.0 Host Controller
> > difference.
> > Best Regards
> > Albert Platek
> > > Hi Albert,
> > > Â
> > > Â
> > > Â
> > > Â
> > run of a big job.
> > > Â
> > > Regards
> > > Â
> > > Â
> > > Hi Tom,
> > > PC No1:
> > > Max segments: 110Â
> > > Time: 31s
> > second.
> > > PC No2:
> > > Max segments: 140Â
> > > Time: 31s
> > second.
> > > PC No3:
> > > Max segments:30Â
> > > Time:31s
> > second.
> > > Max segments:170
> > > Time:31s
> > second.
> > > Max segments:200
> > > Time:31s
> > second.
> > > Max segments:410
> > > Time:31s
> > > Best regards
> > > Albert P³atek
> > > > Hi Albert,
> > > > ÂÂ
> > > > ÂÂ
> > ependent on the path curvature rather than the original GCode.ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > ally shifts the "circle" to make the plot more interesting).ÂÂ
> > > > ÂÂ
> > seconds. So:
> > > > ÂÂ
> > per second.
> > > > ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > 1.1 device is attached it slows everything down.ÂÂ
> > > > ÂÂ
> > > > Regards
> > > > TKÂÂ
> > > > ÂÂ
> > > > ÂÂ
> > > > Hi Tom,
> > for KFlop?
> > > > Break angle 30
> > > > Look ahead 3
> > > > Vel 5
> > > > Best Regards
> > > > Albert Platek
> > > > > Hi Tom,
> > that when I am
> > thats why I
> > > > > Best Regards
> > > > > Albert PÃÆ'…‚atek
> > > > > > Hi Albert,
> > > > > > Thanks
> > > > > > TK
> > > > > > Hi Tom,
> > > > > > My settings:
> > > > > > Break angle 30
> > > > > > Look ahead 3
> > almost from
> > > > > > program start)
> > are fairly
> > > > > > smooth)
> > > > > > Vel 5.0
> > > > > > Accel 40
> > arcs, I will
> > > > > > send file tomorrow)
> > (Dell, core 2
> > work, i often
> > Nvidia Gt555)
> > generation slows
> > > > > > Best Regards
> > > > > > Albert PÃÆ'‚³atek
> > > > > > > Hi Albert,
> > > > > > > ÃÆ'Æ'‚
> > > > > > > Could you send me the Gcode and all your settings?ÃÆ'Æ'Ã
> > ¢â‚¬Å¡ I don't understand
> > > > > > the collinear tolerance of 1?ÃÆ'Æ'‚ That
> > seems huge.ÃÆ'Æ'‚ Did you mean 0.001?
> > > > > > > ÃÆ'Æ'‚
> > generating too many
> > > > > > small segments.ÃÆ'Æ'‚ Are you using the
> > > > > > Smoothing option?ÃÆ'Æ'‚ That might help make
> > > > > > larger facets.
> > > > > > > ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > the
> > > > > > > ÃÆ'Æ'‚
> > > > > > > Regards
> > > > > > > TK
> > > > > > > ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > > > > > > ÃÆ'Æ'‚
> > > > > > > Hi Tom,
> > with same
> > > > > > settings?
> > it possible
> > smoothing
> > > > > > > Best Regards
> > > > > > > Albert PÃÆ'Æ'‚ÃÆ'‚³atek
Group: DynoMotion Message: 3724 From: Tom Kerekes Date: 2/5/2012
Hi Albert,
Thanks for the very complete problem description, I can't tell you how much I appreciate that, but I can't think of anything that would cause this. Anything with large files I might expect some processing issue but that would result in a buffer underflow and an error message not incorrect motion that would result in a stall.  That delay I described in your email only happens when "Execute" is pushed so I don't think it is related.
There is an experimental version KMotion429x.exe on the download site that has this delay eliminated and also faster USB throughput, but I don't think either of those are related to this problem.
Can you post the file somewhere?  I'm thinking to write a C program that would run in KFLOP and watch for too high of acceleration or velocity by monitoring how ch0->Dest changes.  If it detects something bad that could be used as a trigger to help us track it down.
Which axes loose position?
Group: DynoMotion Message: 3725 From: Albert Płatek Date: 2/5/2012
Attachments :
Thank you for help.
Mostly stall X axis, and sometimes Z.
Y axis seem to be ok.
I uploaded file as an attachment (zip).
Best Regards
Albert Platek
2012/2/5 Tom Kerekes <tk@...>
Hi Albert,
Group: DynoMotion Message: 3736 From: albertplatek Date: 2/6/2012
Problem solved (probably), weird but after re-flash firmware 4.28
everything is working ok, no axis stall.
btw. Experimental version KMotion429x.exe is not working, when I start
execute gcode I get message "G Code Error GCode Aborted", this error
occurs on any gcode program even on only few G01 lines.
Tom if you have C program that watch for too high of acceleration
please post it. If again in future something strange will
happen I will try find out the problem.
I am still not sure what was the problem in my system that axis
were stalling.
Best Regards
Albert P³atek
> Hi Tom,
> Thank you for help.
> Best Regards
> Albert Platek
> > Hi Albert,
> > *Sent:* Sunday, February 5, 2012 5:27 AM
> > Hi Tom,
> > My settings:
> > Break angle 30 deg
> > Look ahead 3 sec
> > Facet angle 1.5 deg
> > Tau = 0.008 sec
> > bigger reliefs.
> > stall.
> > Best Regards
> > Albert P³atek
> > --- In DynoMotion@yahoogroups.com, Albert <albertplatek86@> wrote:
> > > Hi Tom,
> > > Thank you.
> > > Best regards
> > > Albert Platek
> > > Dnia 2012-01-18 o godz. 23:47 Tom Kerekes <tk@> napisał
> > > (a):
> > > > Hi Albert,
> > > > Regards
> > > > TK
> > > > Hi Tom,
> > > > rate.
> > > > Btw:
> > > > computer.
> > > > Controller
> > > > 3.0 Host Controller
> > > > difference.
> > > > Best Regards
> > > > Albert Platek
> > > > > Hi Albert,
> > > > > Â
> > > > > Â
> > > > > Â
> > > > > Â
> > > > run of a big job.
> > > > > Â
> > > > > Regards
> > > > > TK
> > > > > Â
> > > > > Â
> > > > > Hi Tom,
> > > > > PC No1:
> > > > > Max segments: 110Â
> > > > > Time: 31s
> > > > second.
> > > > > PC No2:
> > > > > Max segments: 140Â
> > > > > Time: 31s
> > > > second.
> > > > > PC No3:
> > > > > Max segments:30Â
> > > > > Time:31s
> > > > second.
> > > > > Max segments:170
> > > > > Time:31s
> > > > second.
> > > > > Max segments:200
> > > > > Time:31s
> > > > second.
> > > > > Max segments:410
> > > > > Time:31s
> > > > > Best regards
> > > > > Albert P³atek
> > > > > > Hi Albert,
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > movements with typical tiny lengths of only 50~150um.ÃÆ'‚Â The
> > > > collinear tolerance of 0.001 (25um) will cause many blocksÃÆ'‚Â to
> > > > ependent on the path curvature rather than the original GCode.ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > degrees butÃÆ'‚Â can't keep up at 0.3 degrees.
> > > > > > ÃÆ'‚Â
> > > > acceleration.ÃÆ'‚Â Here is what I find:
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > generates an N sided Polygon 100 timesÃÆ'‚Â with radius 0.1 inches
> > > > ally shifts the "circle" to make the plot more interesting).ÃÆ'‚Â
> > > > (see attachment). ÃÆ'‚Â When using the diagnostic make sure to set
> > > > he original segments are used.ÃÆ'‚Â By changing N (number of sides
> > > > > > ÃÆ'‚Â
> > > > = 240.ÃÆ'‚Â The total time to do all 100 circles takes about 30
> > > > seconds.ÃÆ'‚Â So:
> > > > > > ÃÆ'‚Â
> > > > per second.
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > Graphical Display is not aÃÆ'‚Â significant factor.
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > be significantly different I don't know.ÃÆ'‚Â Google finds some
> > > > benchmarking tools but they areÃÆ'‚Â mainly for High Speed USB
> > > > devices like flash drives.ÃÆ'‚Â Some sites state if an older USB
> > > > 1.1 device is attached it slows everything down.ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > Regards
> > > > > > TKÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > ÃÆ'‚Â
> > > > > > Hi Tom,
> > > > for KFlop?
> > > > > > Break angle 30
> > > > > > Look ahead 3
> > > > > > Vel 5
> > > > > > Best Regards
> > > > > > Albert Platek
> > > > > > --- In DynoMotion@yahoogroups.com, Albert PÃÆ'‚³atek
> > > > > > > Hi Tom,
> > > > that when I am
> > > > thats why I
> > > > > > > Best Regards
> > > > > > > Albert PÃÆ'Æ'…ÃÆ'¢â‚¬Å¡atek
> > > > > > > > Hi Albert,
> > > > > > > > Thanks
> > > > > > > > TK
> > > > > > > > Hi Tom,
> > > > > > > > My settings:
> > > > > > > > Break angle 30
> > > > > > > > Look ahead 3
> > > > almost from
> > > > > > > > program start)
> > > > are fairly
> > > > > > > > smooth)
> > > > > > > > Vel 5.0
> > > > > > > > Accel 40
> > > > arcs, I will
> > > > > > > > send file tomorrow)
> > > > (Dell, core 2
> > > > work, i often
> > > > Nvidia Gt555)
> > > > generation slows
> > > > > > > > Best Regards
> > > > > > > > > Hi Albert,
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > Could you send me the Gcode and all your settings?ÃÆ'Æ'Æ'ÃÆ'
> > > > > > > > the collinear tolerance of 1?ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ That
> > > > seems huge.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Did you mean 0.001?
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > generating too many
> > > > > > > > small segments.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Are you using the
> > > > > > > > Smoothing option?ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ That might help make
> > > > > > > > larger facets.
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > the
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > Regards
> > > > > > > > > TK
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > Hi Tom,
> > > > with same
> > > > > > > > settings?
> > > > it possible
> > > > smoothing
> > > > > > > > > Best Regards
> > > > > > > > > Albert PÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
Group: DynoMotion Message: 3738 From: albertplatek Date: 2/6/2012
Sorry Tom but still this happens randomly :/ I was just lucky that after firmware flash 1 job was ok.
I use ver 4.28.
I dont know how to determine line numner of this jerk, but you can see huge acceleration! X motor stalled.
It was runinng about 10min from program start.
Acceleration was set 32in/sec2
Break Angle 30
Tau 0.008
Collinear Tolerance 0.0005
Corener Tolerance 0.01
Facet angle 0.5
Vel 4in/sec
Here is my simple C program to check acceleration please check if it is correct:
#define channel ch0
#define time 0.00018
double X1,X2,speed1,speed2,accel;
int k;
while(1)
for (k=0; k<1; k++) WaitNextTimeSlice();
X1 = channel->Dest;
X2 = channel->Dest;
speed1=(X2-X1)/(time);
X1 = channel->Dest;
X2 = channel->Dest;
speed2=(X2-X1)/(time);
accel=(speed1-speed2)/(time);
accel=(accel/254000)/2;
if(accel>45)
printf("AccelError= %f\n",accel);
Here log:
AccelError= 45.009219
AccelError= 45.229875
AccelError= 46.294106
AccelError= 45.055529
AccelError= 45.747547
AccelError= 45.070729
AccelError= 45.360541
AccelError= 45.765590
AccelError= 46.302076
AccelError= 46.775562
AccelError= 47.051896
AccelError= 45.225101
AccelError= 45.730674
AccelError= 46.758273
AccelError= 46.838768
AccelError= 45.698572
AccelError= 46.918682
AccelError= 45.204219
AccelError= 45.900150
AccelError= 47.023519
AccelError= 47.551550
AccelError= 48.022541
AccelError= 46.395295
AccelError= 81526.314840
AccelError= 72853.056587
AccelError= 65101.872298
AccelError= 58175.992747
AccelError= 51986.611437
AccelError= 46456.046360
AccelError= 41513.718492
AccelError= 37097.300673
AccelError= 33150.797142
AccelError= 29622.770379
AccelError= 26468.350534
AccelError= 23652.797849
AccelError= 21136.323622
AccelError= 18888.213633
AccelError= 16879.065077
AccelError= 15083.474245
AccelError= 13479.186003
AccelError= 12045.566722
AccelError= 10764.204608
AccelError= 9619.483512
AccelError= 8596.141212
AccelError= 7682.015002
AccelError= 6866.662006
AccelError= 6139.961139
AccelError= 5490.446488
AccelError= 4910.042286
AccelError= 4391.574405
AccelError= 3928.114510
AccelError= 3514.000485
AccelError= 3144.002655
AccelError= 2813.316136
AccelError= 2517.500643
AccelError= 2253.490792
AccelError= 2017.432428
AccelError= 1806.266152
AccelError= 1617.706032
AccelError= 1448.982225
AccelError= 1298.398178
AccelError= 1163.621865
AccelError= 1043.472200
AccelError= 935.821407
AccelError= 839.766485
AccelError= 753.863074
AccelError= 677.101783
AccelError= 608.587862
AccelError= 547.209083
AccelError= 492.589836
AccelError= 443.554631
AccelError= 399.735924
AccelError= 360.639632
AccelError= 325.643422
AccelError= 294.370902
AccelError= 266.425861
AccelError= 241.478288
AccelError= 219.191672
AccelError= 199.246085
AccelError= 181.422761
AccelError= 165.532090
AccelError= 151.295897
AccelError= 138.574472
AccelError= 127.206640
AccelError= 117.084135
AccelError= 108.003075
AccelError= 99.888264
AccelError= 92.598183
AccelError= 86.122270
AccelError= 76.770777
AccelError= 65.225363
AccelError= 54.908134
AccelError= 45.688617
AccelError= 45.070435
AccelError= 45.411744
AccelError= 45.770036
AccelError= 45.871485
AccelError= 45.239885
AccelError= 45.631836
AccelError= 45.001237
AccelError= 45.373033
AccelError= 45.577907
AccelError= 46.322608
AccelError= 46.958820
AccelError= 46.038556
AccelError= 45.018088
If you test it on your PC and will be ok, then maybe something is wrong with my laptop. Then I will test on other PC.
Best Regards
Albert P³atek
--- In DynoMotion@yahoogroups.com, "albertplatek" <albertplatek86@...> wrote:
> Hi Tom,
> were stalling.
> Best Regards
> Albert P³atek
> --- In DynoMotion@yahoogroups.com, Albert P³atek <albertplatek86@> wrote:
> > Hi Tom,
> > Thank you for help.
> > Best Regards
> > Albert Platek
> > 2012/2/5 Tom Kerekes <tk@>
> > > Hi Albert,
> > > Regards
> > > *From:* albertplatek <albertplatek86@>
> > > Hi Tom,
> > > My settings:
> > > Break angle 30 deg
> > > Look ahead 3 sec
> > > Facet angle 1.5 deg
> > > Tau = 0.008 sec
> > > bigger reliefs.
> > > stall.
> > > Best Regards
> > > Albert P³atek
> > > > Hi Tom,
> > > > Thank you.
> > > > Best regards
> > > > Albert Platek
> > > > (a):
> > > > > Hi Albert,
> > > > > Regards
> > > > > TK
> > > > > Hi Tom,
> > > > > rate.
> > > > > Btw:
> > > > > computer.
> > > > > Controller
> > > > > 3.0 Host Controller
> > > > > difference.
> > > > > Best Regards
> > > > > Albert Platek
> > > > > > Hi Albert,
> > > > > > Â
> > > > > > Â
> > > > > > Â
> > > > > > Â
> > > > > run of a big job.
> > > > > > Â
> > > > > > Regards
> > > > > > TK
> > > > > > Â
> > > > > > Â
> > > > > > Hi Tom,
> > > > > > PC No1:
> > > > > > Max segments: 110Â
> > > > > > Time: 31s
> > > > > second.
> > > > > > PC No2:
> > > > > > Max segments: 140Â
> > > > > > Time: 31s
> > > > > second.
> > > > > > PC No3:
> > > > > > Max segments:30Â
> > > > > > Time:31s
> > > > > second.
> > > > > > Max segments:170
> > > > > > Time:31s
> > > > > second.
> > > > > > Max segments:200
> > > > > > Time:31s
> > > > > second.
> > > > > > Max segments:410
> > > > > > Time:31s
> > > > > > Best regards
> > > > > > Albert P³atek
> > > > > > > Hi Albert,
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > seconds.ÃÆ'‚Â So:
> > > > > > > ÃÆ'‚Â
> > > > > per second.
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > Regards
> > > > > > > TKÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > ÃÆ'‚Â
> > > > > > > Hi Tom,
> > > > > for KFlop?
> > > > > > > Break angle 30
> > > > > > > Look ahead 3
> > > > > > > Vel 5
> > > > > > > Best Regards
> > > > > > > Albert Platek
> > > > > > > > Hi Tom,
> > > > > that when I am
> > > > > thats why I
> > > > > > > > Best Regards
> > > > > > > > > Hi Albert,
> > > > > > > > > Thanks
> > > > > > > > > TK
> > > > > > > > > Hi Tom,
> > > > > > > > > My settings:
> > > > > > > > > Break angle 30
> > > > > > > > > Look ahead 3
> > > > > almost from
> > > > > > > > > program start)
> > > > > are fairly
> > > > > > > > > smooth)
> > > > > > > > > Vel 5.0
> > > > > > > > > Accel 40
> > > > > arcs, I will
> > > > > > > > > send file tomorrow)
> > > > > (Dell, core 2
> > > > > work, i often
> > > > > Nvidia Gt555)
> > > > > generation slows
> > > > > > > > > Best Regards
> > > > > > > > > > Hi Albert,
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > generating too many
> > > > > > > > > larger facets.
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > the
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > Regards
> > > > > > > > > > TK
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > Hi Tom,
> > > > > with same
> > > > > > > > > settings?
> > > > > it possible
> > > > > smoothing
> > > > > > > > > > Best Regards
Group: DynoMotion Message: 3753 From: Tom Kerekes Date: 2/6/2012
Attachments :
Hi Albert,
Your program seems reasonable but the numbers are crazy.
So are you saying that it did not report any errors until after 10 minutes then printed those?
I made a similar program and ran it over night and didn't see such a problem.  See attached.  It displays the velocity and acceleration into unused axes 6 and 7 Destinations on the Axis Screen. It also captures the Max Velocity and Acceleration and displays those as 6 and 7 Positions.
To be honest I see some tiny glitches and anomolies probably due to numerical rounding that I would like to better understand, but with the smoothing filter of 8ms it attenuates them way down.  The biggest acceleration spike I see in the entire multi hour job is 90 in/sec2.
Did you have the smoothing turned on?
Is your Resolution 254,000 steps per inch?
You don't have an MPG connected do you?
I will try your program to see if I get similar results.
Group: DynoMotion Message: 3777 From: Albert Płatek Date: 2/7/2012
Subject: Re: Coord buffer overflow again [1 Attachment]
"So are you saying that it did not report any errors until after 10 minutes then printed those?"
- It was printing accel peak around 60in/sec2 sometimes from start and after 10 min this big error.  Second job execute was ok by about 20min then again error.
Smoothing was Tau= 0.008.
I just made new test on other pc with file "test_tolerance_0.005.ngc" . And I got 1166in/sec2 acceleration peak... and it stalled X motor.
It is same program as before but with toolpath tolerance of 0.005. I thought that maybe this will help. But it didnt. (old file Relief14.ngc had toolpath tolerance of 0.01)
Small programs works even with extream acceleration of 60, but this program and other bigger programs fail even with acceleration of 20.
Here all my settings:
Trajectory planner
Break Angle 30 degrees
Look Ahead 3 sec
Collinear Tolerance 0.0005 in
Corner Tolerance 0.01 in
Facet Angle 1.5
Axis Parameters
X Resolution 254000 Vel 5 Accel 40
Y Resolution 127000 Vel 4 Accel 10
Z Resolution 254000 Vel 5 Accel 40
A Resolution 7055.5555 Vel 100 Accel 15 (I dont use this axis in programs at moment)
Smoothing Tau = 0.01
Gamepad disabled
Lathe disabled
I dont use MPG and it is not connected.
Gcode program (test_tolerance_0.005.ngc) started from first line, I was only capturing Acceleration > 58.
Wt, lut 07, 2012, 12:42:31  KMotion Program Started
TAU = 0.010000
ACCEL= 58.677936
ACCEL= 58.927802
ACCEL= 58.960033
ACCEL= 60.769580
ACCEL= 58.512884
ACCEL= 58.924281
ACCEL= 59.024541
ACCEL= 58.133892
ACCEL= 61.956729
ACCEL= 59.006616
ACCEL= 60.105317
ACCEL= 58.828274
ACCEL= 60.622193
ACCEL= 58.060298
ACCEL= 60.837834
ACCEL= 58.185082
ACCEL= 58.925759
ACCEL= 59.444038
ACCEL= 61.017190
ACCEL= 59.082489
ACCEL= 60.176545
ACCEL= 58.677989
ACCEL= 60.129486
ACCEL= 59.890981
ACCEL= 63.703736
ACCEL= 58.300426
ACCEL= 58.390017
ACCEL= 64.994889
ACCEL= 61.344673
ACCEL= 61.264344
ACCEL= 60.206659
ACCEL= 61.110118
ACCEL= 58.861575
ACCEL= 62.844393
ACCEL= 58.712601
ACCEL= 62.743716
ACCEL= 59.412413
ACCEL= 59.090724
ACCEL= 59.607079
ACCEL= 58.240991
ACCEL= 58.200542
ACCEL= 62.400201
ACCEL= 64.401300
ACCEL= 60.829834
ACCEL= 60.765056
ACCEL= 58.584326
ACCEL= 59.368296
ACCEL= 58.845166
ACCEL= 63.692201
ACCEL= 59.398388
ACCEL= 58.492754
ACCEL= 58.201424
ACCEL= 59.713704
ACCEL= 59.488310
ACCEL= 58.663588
ACCEL= 62.887233
ACCEL= 58.256548
ACCEL= 58.483484
ACCEL= 58.042246
ACCEL= 58.518015
ACCEL= 61.312055
ACCEL= 60.224222
ACCEL= 60.041371
ACCEL= 61.019005
ACCEL= 59.857207
ACCEL= 60.667182
ACCEL= 62.517183
ACCEL= 62.978943
ACCEL= 60.672158
ACCEL= 62.764637
ACCEL= 60.755186
ACCEL= 58.177374
ACCEL= 58.144752
ACCEL= 62.349561
ACCEL= 59.094084
ACCEL= 59.707611
ACCEL= 60.042771
ACCEL= 59.493590
ACCEL= 58.381740
ACCEL= 58.552432
ACCEL= 60.385809
ACCEL= 61.290063
ACCEL= 63.347741
ACCEL= 59.724964
ACCEL= 66.035414
ACCEL= 58.827807
ACCEL= 60.704297
ACCEL= 60.619439
ACCEL= 60.255062
ACCEL= 59.246636
ACCEL= 58.966244
ACCEL= 62.119289
ACCEL= 61.110753
ACCEL= 64.018676
ACCEL= 63.911028
ACCEL= 60.811810
ACCEL= 59.177635
ACCEL= 61.196853
ACCEL= 58.680083
ACCEL= 59.527456
ACCEL= 58.087839
ACCEL= 59.119465
ACCEL= 62.853732
ACCEL= 59.093458
ACCEL= 59.161929
ACCEL= 61.429357
ACCEL= 58.803188
ACCEL= 59.175222
ACCEL= 60.219244
ACCEL= 58.596575
ACCEL= 58.764846
ACCEL= 58.426363
ACCEL= 60.086656
ACCEL= 59.610107
ACCEL= 59.229815
ACCEL= 58.044244
ACCEL= 63.695621
ACCEL= 58.131310
ACCEL= 59.107058
ACCEL= 58.927665
ACCEL= 61.165485
ACCEL= 58.315186
ACCEL= 60.871648
ACCEL= 60.176458
ACCEL= 59.214217
ACCEL= 59.208457
ACCEL= 62.621824
ACCEL= 58.398335
ACCEL= 61.152436
ACCEL= 58.604786
ACCEL= 58.729217
ACCEL= 59.923425
ACCEL= 59.677849
ACCEL= 58.123086
ACCEL= 60.433701
ACCEL= 58.291893
ACCEL= 60.252449
ACCEL= 60.417103
ACCEL= 60.433561
ACCEL= 61.127250
ACCEL= 61.402805
ACCEL= 58.202147
ACCEL= 62.299667
ACCEL= 62.973329
ACCEL= 61.678133
ACCEL= 58.407879
ACCEL= 59.317560
ACCEL= 58.968064
ACCEL= 58.048711
ACCEL= 58.288685
ACCEL= 58.241909
ACCEL= 59.930745
ACCEL= 59.450933
ACCEL= 59.439070
ACCEL= 58.143918
ACCEL= 58.259981
ACCEL= 58.482531
ACCEL= 58.101452
ACCEL= 60.411654
ACCEL= 60.631439
ACCEL= 62.469302
ACCEL= 60.847604
ACCEL= 58.350368
ACCEL= 1166.694794
ACCEL= 450.118253
ACCEL= 186.931892
ACCEL= 91.714558
ACCEL= 60.190257
ACCEL= 60.530275
ACCEL= 59.028122
Here I stopped program line was N463261.
Smoothing TAU 0.01
In attechement  INIT.c config program.
GCode program is in Yahoo Files folder "Albert CNC files "  (test_tolerance_0.005.part01.rar and test_tolerance_0.005.part02.rar)
Best Regards
Albert Platek
2012/2/7 Tom Kerekes <tk@...>
Hi Albert,
Group: DynoMotion Message: 3808 From: albertplatek Date: 2/8/2012
I think that in 99% I found bug, it was gamepad connected into usb.
Even if it was disabled in KMmotionCNC, it was causing randomly this
crazy jerk of acceleration. Today I tested this big gcode program 3 times without gamepad and everything is fine! :)
Best Regards
Albert P³atek
> Hi Tom,
> again error.
> I got *1166in/sec2* acceleration peak... and it stalled X motor.
> *Trajectory planner*
> Look Ahead 3 sec
> Facet Angle 1.5
> *Axis Parameters*
> at moment)
> Gamepad disabled
> Lathe disabled
> TAU = 0.010000
> ACCEL= 58.677936
> ACCEL= 58.927802
> ACCEL= 58.960033
> ACCEL= 60.769580
> ACCEL= 58.512884
> ACCEL= 58.924281
> ACCEL= 59.024541
> ACCEL= 58.133892
> ACCEL= 61.956729
> ACCEL= 59.006616
> ACCEL= 60.105317
> ACCEL= 58.828274
> ACCEL= 60.622193
> ACCEL= 58.060298
> ACCEL= 60.837834
> ACCEL= 58.185082
> ACCEL= 58.925759
> ACCEL= 59.444038
> ACCEL= 61.017190
> ACCEL= 59.082489
> ACCEL= 60.176545
> ACCEL= 58.677989
> ACCEL= 60.129486
> ACCEL= 59.890981
> ACCEL= 63.703736
> ACCEL= 58.300426
> ACCEL= 58.390017
> ACCEL= 64.994889
> ACCEL= 61.344673
> ACCEL= 61.264344
> ACCEL= 60.206659
> ACCEL= 61.110118
> ACCEL= 58.861575
> ACCEL= 62.844393
> ACCEL= 58.712601
> ACCEL= 62.743716
> ACCEL= 59.412413
> ACCEL= 59.090724
> ACCEL= 59.607079
> ACCEL= 58.240991
> ACCEL= 58.200542
> ACCEL= 62.400201
> ACCEL= 64.401300
> ACCEL= 60.829834
> ACCEL= 60.765056
> ACCEL= 58.584326
> ACCEL= 59.368296
> ACCEL= 58.845166
> ACCEL= 63.692201
> ACCEL= 59.398388
> ACCEL= 58.492754
> ACCEL= 58.201424
> ACCEL= 59.713704
> ACCEL= 59.488310
> ACCEL= 58.663588
> ACCEL= 62.887233
> ACCEL= 58.256548
> ACCEL= 58.483484
> ACCEL= 58.042246
> ACCEL= 58.518015
> ACCEL= 61.312055
> ACCEL= 60.224222
> ACCEL= 60.041371
> ACCEL= 61.019005
> ACCEL= 59.857207
> ACCEL= 60.667182
> ACCEL= 62.517183
> ACCEL= 62.978943
> ACCEL= 60.672158
> ACCEL= 62.764637
> ACCEL= 60.755186
> ACCEL= 58.177374
> ACCEL= 58.144752
> ACCEL= 62.349561
> ACCEL= 59.094084
> ACCEL= 59.707611
> ACCEL= 60.042771
> ACCEL= 59.493590
> ACCEL= 58.381740
> ACCEL= 58.552432
> ACCEL= 60.385809
> ACCEL= 61.290063
> ACCEL= 63.347741
> ACCEL= 59.724964
> ACCEL= 66.035414
> ACCEL= 58.827807
> ACCEL= 60.704297
> ACCEL= 60.619439
> ACCEL= 60.255062
> ACCEL= 59.246636
> ACCEL= 58.966244
> ACCEL= 62.119289
> ACCEL= 61.110753
> ACCEL= 64.018676
> ACCEL= 63.911028
> ACCEL= 60.811810
> ACCEL= 59.177635
> ACCEL= 61.196853
> ACCEL= 58.680083
> ACCEL= 59.527456
> ACCEL= 58.087839
> ACCEL= 59.119465
> ACCEL= 62.853732
> ACCEL= 59.093458
> ACCEL= 59.161929
> ACCEL= 61.429357
> ACCEL= 58.803188
> ACCEL= 59.175222
> ACCEL= 60.219244
> ACCEL= 58.596575
> ACCEL= 58.764846
> ACCEL= 58.426363
> ACCEL= 60.086656
> ACCEL= 59.610107
> ACCEL= 59.229815
> ACCEL= 58.044244
> ACCEL= 63.695621
> ACCEL= 58.131310
> ACCEL= 59.107058
> ACCEL= 58.927665
> ACCEL= 61.165485
> ACCEL= 58.315186
> ACCEL= 60.871648
> ACCEL= 60.176458
> ACCEL= 59.214217
> ACCEL= 59.208457
> ACCEL= 62.621824
> ACCEL= 58.398335
> ACCEL= 61.152436
> ACCEL= 58.604786
> ACCEL= 58.729217
> ACCEL= 59.923425
> ACCEL= 59.677849
> ACCEL= 58.123086
> ACCEL= 60.433701
> ACCEL= 58.291893
> ACCEL= 60.252449
> ACCEL= 60.417103
> ACCEL= 60.433561
> ACCEL= 61.127250
> ACCEL= 61.402805
> ACCEL= 58.202147
> ACCEL= 62.299667
> ACCEL= 62.973329
> ACCEL= 61.678133
> ACCEL= 58.407879
> ACCEL= 59.317560
> ACCEL= 58.968064
> ACCEL= 58.048711
> ACCEL= 58.288685
> ACCEL= 58.241909
> ACCEL= 59.930745
> ACCEL= 59.450933
> ACCEL= 59.439070
> ACCEL= 58.143918
> ACCEL= 58.259981
> ACCEL= 58.482531
> ACCEL= 58.101452
> ACCEL= 60.411654
> ACCEL= 60.631439
> ACCEL= 62.469302
> ACCEL= 60.847604
> ACCEL= 58.350368
> *ACCEL= 1166.694794
> ACCEL= 450.118253*
> ACCEL= 186.931892
> ACCEL= 91.714558
> ACCEL= 60.190257
> ACCEL= 60.530275
> ACCEL= 59.028122
> Smoothing TAU 0.01
> Best Regards
> Albert Platek
> > [Attachment(s)<https://mail.google.com/mail/html/compose/static_files/blank_quirks.html#1355587bcb0eb6ec_TopText>from Tom Kerekes included below]
> > Hi Albert,
> > then printed those?
> > Thanks
> > *Sent:* Monday, February 6, 2012 8:24 AM
> > Hi Tom,
> > I use ver 4.28.
> > Break Angle 30
> > Tau 0.008
> > Facet angle 0.5
> > Vel 4in/sec
> > correct:
> > #include "KMotionDef.h"
> > #define channel ch0
> > main()
> > int k;
> > while(1)
> > X1 = channel->Dest;
> > X2 = channel->Dest;
> > X1 = channel->Dest;
> > X2 = channel->Dest;
> > if(accel>45)
> > Here log:
> > Best Regards
> > Albert P³atek
> > --- In DynoMotion@yahoogroups.com, "albertplatek" <albertplatek86@>
> > wrote:
> > > Hi Tom,
> > > were stalling.
> > > Best Regards
> > > Albert P³atek
> > wrote:
> > > > Hi Tom,
> > > > Thank you for help.
> > > > Best Regards
> > > > Albert Platek
> > > > > Hi Albert,
> > how
> > cause
> > but
> > incorrect
> > email
> > don't
> > that
> > velocity by
> > could
> > > > > Regards
> > > > > TK
> > > > > Hi Tom,
> > > > > My settings:
> > > > > Break angle 30 deg
> > > > > Look ahead 3 sec
> > > > > Facet angle 1.5 deg
> > > > > Tau = 0.008 sec
> > > > > bigger reliefs.
> > 274000
> > with
> > didnt
> > > > > stall.
> > There
> > Halts to go
> > data,
> > discarding
> > way in
> > annoying
> > > > > Best Regards
> > > > > Albert P³atek
> > > > > > Hi Tom,
> > > > > > Thank you.
> > > > > > Best regards
> > > > > > Albert Platek
> > > > > > (a):
> > > > > > > Hi Albert,
> > USB
> > > > > > > Regards
> > > > > > > TK
> > > > > > > Hi Tom,
> > segment
> > > > > > > rate.
> > > > > > > Btw:
> > tested
> > > > > > > computer.
> > helps.
> > > > > > > Controller
> > > > > > > 3.0 Host Controller
> > no
> > > > > > > difference.
> > > > > > > Best Regards
> > > > > > > Albert Platek
> > > > > > > > Hi Albert,
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > seem to
> > > > > > > > ÃÆ'‚
> > KFLOP.ÃÆ'‚ I
> > > > > > > > ÃÆ'‚
> > before
> > > > > > > .ÃÆ'‚ There is an annoying ~30 second delay when it runs the
> > second ti
> > > > > > > me.ÃÆ'‚ The Interpreter keeps a record of all its state changes
> > which
> > > > > > > allow Halts to go back to any previous state.ÃÆ'‚ In this test
> > of 100x
> > changes.ÃÆ'‚ Iro
> > the
> > 30
> > > > > > > seconds!ÃÆ'‚ We will find a better way in the next
> > version.ÃÆ'‚ For now
> > > > > > > just don't be surprisedÃÆ'‚ if there is an annoying delay on a
> > second
> > > > > > > run of a big job.
> > > > > > > > ÃÆ'‚
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > ÃÆ'‚
> > > > > > > > ÃÆ'‚
> > > > > > > > Hi Tom,
> > > > > > > > PC No1:
> > > > > > > > Max segments: 110ÃÆ'‚
> > > > > > > > Time: 31s
> > per
> > > > > > > second.
> > > > > > > > PC No2:
> > > > > > > > Max segments: 140ÃÆ'‚
> > > > > > > > Time: 31s
> > per
> > > > > > > second.
> > > > > > > > PC No3:
> > > > > > > > Max segments:30ÃÆ'‚
> > > > > > > > Time:31s
> > per
> > > > > > > second.
> > > > > > > > Max segments:170
> > > > > > > > Time:31s
> > per
> > > > > > > second.
> > > > > > > > Max segments:200
> > > > > > > > Time:31s
> > per
> > > > > > > second.
> > aslo
> > > > > > > > Max segments:410
> > > > > > > > Time:31s
> > per
> > 7
> > > > > > > > Fidelizer software only improved performance on pc with ÃÆ'‚
> > Win7.
> > > > > > > > Best regards
> > > > > > > > Albert PÃÆ'‚³atek
> > > > > > > > > Hi Albert,
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > 50~150um.ÃÆ'Æ'‚ÃÆ'‚ The
> > blocksÃÆ'Æ'‚ÃÆ'‚ to
> > more d
> > GCode.ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > 0.4
> > > > > > > degrees butÃÆ'Æ'‚ÃÆ'‚ can't keep up at 0.3 degrees.
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > in/sec2
> > > > > > > acceleration.ÃÆ'Æ'‚ÃÆ'‚ Here is what I find:
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > circle
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > generates an N sided Polygon 100 timesÃÆ'Æ'‚ÃÆ'‚ with
> > radius 0.1 inches
> > gradu
> > interesting).ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > (see attachment). ÃÆ'Æ'‚ÃÆ'‚ When using the diagnostic
> > make sure to set
> > so t
> > > > > > > he original segments are used.ÃÆ'Æ'‚ÃÆ'‚ By changing N
> > (number of sides
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > with N
> > > > > > > = 240.ÃÆ'Æ'‚ÃÆ'‚ The total time to do all 100 circles
> > takes about 30
> > > > > > > seconds.ÃÆ'Æ'‚ÃÆ'‚ So:
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > per second.
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > in
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > the
> > > > > > > Graphical Display is not aÃÆ'Æ'‚ÃÆ'‚ significant factor.
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > would
> > > > > > > be significantly different I don't know.ÃÆ'Æ'‚ÃÆ'‚ Google
> > finds some
> > > > > > > benchmarking tools but they areÃÆ'Æ'‚ÃÆ'‚ mainly for High
> > Speed USB
> > > > > > > devices like flash drives.ÃÆ'Æ'‚ÃÆ'‚ Some sites state if
> > an older USB
> > > > > > > 1.1 device is attached it slows everything down.ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > Regards
> > > > > > > > > TKÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > > > > > Hi Tom,
> > best
> > > > > > > for KFlop?
> > even I
> > sometimes
> > installation,
> > facet
> > > > > > > > > Break angle 30
> > > > > > > > > Look ahead 3
> > > > > > > > > Vel 5
> > > > > > > > > Best Regards
> > > > > > > > > Albert Platek
> > PÃÆ'Æ'‚ÃÆ'‚³atek
> > > > > > > > > > Hi Tom,
> > > > > > > that when I am
> > > > > > > thats why I
> > > > > > > > > > Best Regards
> > > > > > > > > > Albert
> > PÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡atek
> > > > > > > > > > > Hi Albert,
> > 300ipm?
> > > > > > > > > > > Thanks
> > > > > > > > > > > TK
> > > > > > > > > > > Hi Tom,
> > > > > > > > > > > My settings:
> > > > > > > > > > > Break angle 30
> > > > > > > > > > > Look ahead 3
> > overflow
> > > > > > > almost from
> > > > > > > > > > > program start)
> > > > > > > are fairly
> > > > > > > > > > > smooth)
> > > > > > > > > > > Vel 5.0
> > > > > > > > > > > Accel 40
> > > > > > > arcs, I will
> > > > > > > > > > > send file tomorrow)
> > ok
> > > > > > > (Dell, core 2
> > > > > > > work, i often
> > > > > > > Nvidia Gt555)
> > > > > > > generation slows
> > > > > > > > > > > Best Regards
> > wrote:
> > > > > > > > > > > > Hi Albert,
> > > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡
> > settings?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'
> > > > > > > ¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ I don't understand
> > 1?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ That
> > > > > > > seems huge.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ Did you
> > mean 0.001?
> > > > > > > generating too many
> > > > > > > > > > > small
> > segments.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ Are you using the
> > > > > > > > > > > Smoothing
> > option?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ That might help make
> > > > > > > > > > > larger facets.
> > other.
> > from
> > > > > > > the
> > > > > > > > > > > > TK
> > > > > > > > > > > > Hi Tom,
> > > > > > > with same
> > > > > > > > > > > settings?
> > is
> > > > > > > it possible
> > > > > > > smoothing
> > > > > > > > > > > > Best Regards
> > > > > > > > > > > > Albert
> > PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
Group: DynoMotion Message: 3812 From: Tom Kerekes Date: 2/8/2012
Hi Albert,
Wow that is strange.  I just double checked and V4.28 is in fact testing the Gampad enable option.  So I have no explaination how the Gampad could make a difference.  Possibly it somehow corrupts the USB communication - but that should generate an error.  Maybe it causes Coordinated Motion Segments to just get completely lost (skipped).
That is something I couldn't understand about the problem, there should be no randomness.  Everything we are doing should be completely deterministic.  The same GCode and the same Settings should generate the exact same motion every time.
Have you tried re-connecting the GamPad and pushing the buttons to see if you can force errors?
Group: DynoMotion Message: 3814 From: albertplatek Date: 2/8/2012
"Have you tried re-connecting the GamPad and pushing the buttons to see if you can force errors?"
- no nothing happen, accelerations are normal.
I am happy that it is finally working and I finished this big reliefs. I can test tomorrow same gcode with gamepad connected to pc and check if it will happen again.
Best Regards
Albert P³atek
> Hi Albert,
> Hi Tom,
> Best Regards
> Albert P³atek
> > Hi Tom,
> > again error.
> > Look Ahead 3 sec
> > Facet Angle 1.5
> > *Axis Parameters*
> > at moment)
> > Gamepad disabled
> > Lathe disabled
> > TAU = 0.010000
> > ACCEL= 58.677936
> > ACCEL= 58.927802
> > ACCEL= 58.960033
> > ACCEL= 60.769580
> > ACCEL= 58.512884
> > ACCEL= 58.924281
> > ACCEL= 59.024541
> > ACCEL= 58.133892
> > ACCEL= 61.956729
> > ACCEL= 59.006616
> > ACCEL= 60.105317
> > ACCEL= 58.828274
> > ACCEL= 60.622193
> > ACCEL= 58.060298
> > ACCEL= 60.837834
> > ACCEL= 58.185082
> > ACCEL= 58.925759
> > ACCEL= 59.444038
> > ACCEL= 61.017190
> > ACCEL= 59.082489
> > ACCEL= 60.176545
> > ACCEL= 58.677989
> > ACCEL= 60.129486
> > ACCEL= 59.890981
> > ACCEL= 63.703736
> > ACCEL= 58.300426
> > ACCEL= 58.390017
> > ACCEL= 64.994889
> > ACCEL= 61.344673
> > ACCEL= 61.264344
> > ACCEL= 60.206659
> > ACCEL= 61.110118
> > ACCEL= 58.861575
> > ACCEL= 62.844393
> > ACCEL= 58.712601
> > ACCEL= 62.743716
> > ACCEL= 59.412413
> > ACCEL= 59.090724
> > ACCEL= 59.607079
> > ACCEL= 58.240991
> > ACCEL= 58.200542
> > ACCEL= 62.400201
> > ACCEL= 64.401300
> > ACCEL= 60.829834
> > ACCEL= 60.765056
> > ACCEL= 58.584326
> > ACCEL= 59.368296
> > ACCEL= 58.845166
> > ACCEL= 63.692201
> > ACCEL= 59.398388
> > ACCEL= 58.492754
> > ACCEL= 58.201424
> > ACCEL= 59.713704
> > ACCEL= 59.488310
> > ACCEL= 58.663588
> > ACCEL= 62.887233
> > ACCEL= 58.256548
> > ACCEL= 58.483484
> > ACCEL= 58.042246
> > ACCEL= 58.518015
> > ACCEL= 61.312055
> > ACCEL= 60.224222
> > ACCEL= 60.041371
> > ACCEL= 61.019005
> > ACCEL= 59.857207
> > ACCEL= 60.667182
> > ACCEL= 62.517183
> > ACCEL= 62.978943
> > ACCEL= 60.672158
> > ACCEL= 62.764637
> > ACCEL= 60.755186
> > ACCEL= 58.177374
> > ACCEL= 58.144752
> > ACCEL= 62.349561
> > ACCEL= 59.094084
> > ACCEL= 59.707611
> > ACCEL= 60.042771
> > ACCEL= 59.493590
> > ACCEL= 58.381740
> > ACCEL= 58.552432
> > ACCEL= 60.385809
> > ACCEL= 61.290063
> > ACCEL= 63.347741
> > ACCEL= 59.724964
> > ACCEL= 66.035414
> > ACCEL= 58.827807
> > ACCEL= 60.704297
> > ACCEL= 60.619439
> > ACCEL= 60.255062
> > ACCEL= 59.246636
> > ACCEL= 58.966244
> > ACCEL= 62.119289
> > ACCEL= 61.110753
> > ACCEL= 64.018676
> > ACCEL= 63.911028
> > ACCEL= 60.811810
> > ACCEL= 59.177635
> > ACCEL= 61.196853
> > ACCEL= 58.680083
> > ACCEL= 59.527456
> > ACCEL= 58.087839
> > ACCEL= 59.119465
> > ACCEL= 62.853732
> > ACCEL= 59.093458
> > ACCEL= 59.161929
> > ACCEL= 61.429357
> > ACCEL= 58.803188
> > ACCEL= 59.175222
> > ACCEL= 60.219244
> > ACCEL= 58.596575
> > ACCEL= 58.764846
> > ACCEL= 58.426363
> > ACCEL= 60.086656
> > ACCEL= 59.610107
> > ACCEL= 59.229815
> > ACCEL= 58.044244
> > ACCEL= 63.695621
> > ACCEL= 58.131310
> > ACCEL= 59.107058
> > ACCEL= 58.927665
> > ACCEL= 61.165485
> > ACCEL= 58.315186
> > ACCEL= 60.871648
> > ACCEL= 60.176458
> > ACCEL= 59.214217
> > ACCEL= 59.208457
> > ACCEL= 62.621824
> > ACCEL= 58.398335
> > ACCEL= 61.152436
> > ACCEL= 58.604786
> > ACCEL= 58.729217
> > ACCEL= 59.923425
> > ACCEL= 59.677849
> > ACCEL= 58.123086
> > ACCEL= 60.433701
> > ACCEL= 58.291893
> > ACCEL= 60.252449
> > ACCEL= 60.417103
> > ACCEL= 60.433561
> > ACCEL= 61.127250
> > ACCEL= 61.402805
> > ACCEL= 58.202147
> > ACCEL= 62.299667
> > ACCEL= 62.973329
> > ACCEL= 61.678133
> > ACCEL= 58.407879
> > ACCEL= 59.317560
> > ACCEL= 58.968064
> > ACCEL= 58.048711
> > ACCEL= 58.288685
> > ACCEL= 58.241909
> > ACCEL= 59.930745
> > ACCEL= 59.450933
> > ACCEL= 59.439070
> > ACCEL= 58.143918
> > ACCEL= 58.259981
> > ACCEL= 58.482531
> > ACCEL= 58.101452
> > ACCEL= 60.411654
> > ACCEL= 60.631439
> > ACCEL= 62.469302
> > ACCEL= 60.847604
> > ACCEL= 58.350368
> > *ACCEL= 1166.694794
> > ACCEL= 450.118253*
> > ACCEL= 186.931892
> > ACCEL= 91.714558
> > ACCEL= 60.190257
> > ACCEL= 60.530275
> > ACCEL= 59.028122
> > Smoothing TAU 0.01
> > Best Regards
> > Albert Platek
> > 2012/2/7 Tom Kerekes <tk@>
> > > Hi Albert,
> > > then printed those?
> > > Thanks
> > > Hi Tom,
> > > I use ver 4.28.
> > > Break Angle 30
> > > Tau 0.008
> > > Facet angle 0.5
> > > Vel 4in/sec
> > > correct:
> > > #define channel ch0
> > > main()
> > > int k;
> > > while(1)
> > > X1 = channel->Dest;
> > > X2 = channel->Dest;
> > > X1 = channel->Dest;
> > > X2 = channel->Dest;
> > > if(accel>45)
> > > Here log:
> > > Best Regards
> > > Albert P³atek
> > > wrote:
> > > > Hi Tom,
> > > > were stalling.
> > > > Best Regards
> > > > Albert P³atek
> > > wrote:
> > > > > Hi Tom,
> > > > > Thank you for help.
> > > > > Best Regards
> > > > > Albert Platek
> > > > > > Hi Albert,
> > > how
> > > cause
> > > but
> > > incorrect
> > > email
> > > don't
> > > that
> > > velocity by
> > > could
> > > > > > Regards
> > > > > > TK
> > > > > > Hi Tom,
> > > > > > My settings:
> > > > > > Break angle 30 deg
> > > > > > Look ahead 3 sec
> > > > > > Facet angle 1.5 deg
> > > > > > Tau = 0.008 sec
> > > > > > bigger reliefs.
> > > 274000
> > > with
> > > didnt
> > > > > > stall.
> > > There
> > > Halts to go
> > > data,
> > > discarding
> > > way in
> > > annoying
> > > > > > Best Regards
> > > > > > Albert P³atek
> > > > > > > Hi Tom,
> > > > > > > Thank you.
> > > > > > > Best regards
> > > > > > > Albert Platek
> > > > > > > Dnia 2012-01-18 o godz. 23:47 Tom Kerekes <tk@> napisaÃÆ'…‚
> > > > > > > (a):
> > > > > > > > Hi Albert,
> > > USB
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > Hi Tom,
> > > segment
> > > > > > > > rate.
> > > > > > > > Btw:
> > > tested
> > > > > > > > computer.
> > > helps.
> > > > > > > > Controller
> > > > > > > > 3.0 Host Controller
> > > no
> > > > > > > > difference.
> > > > > > > > Best Regards
> > > > > > > > Albert Platek
> > > > > > > > > Hi Albert,
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > ÃÆ'Æ'‚
> > > seem to
> > > > > > > > > ÃÆ'Æ'‚
> > > KFLOP.ÃÆ'Æ'‚ I
> > > > > > > > > ÃÆ'Æ'‚
> > > before
> > > > > > > > .ÃÆ'Æ'‚ There is an annoying ~30 second delay when it runs the
> > > second ti
> > > > > > > > me.ÃÆ'Æ'‚ The Interpreter keeps a record of all its state changes
> > > which
> > > > > > > > allow Halts to go back to any previous state.ÃÆ'Æ'‚ In this test
> > > of 100x
> > > changes.ÃÆ'Æ'‚ Iro
> > > the
> > > 30
> > > > > > > > seconds!ÃÆ'Æ'‚ We will find a better way in the next
> > > version.ÃÆ'Æ'‚ For now
> > > > > > > > just don't be surprisedÃÆ'Æ'‚ if there is an annoying delay on a
> > > second
> > > > > > > > run of a big job.
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > Regards
> > > > > > > > > TK
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > Hi Tom,
> > > > > > > > > PC No1:
> > > > > > > > > Max segments: 110ÃÆ'Æ'‚
> > > > > > > > > Time: 31s
> > > per
> > > > > > > > second.
> > > > > > > > > PC No2:
> > > > > > > > > Max segments: 140ÃÆ'Æ'‚
> > > > > > > > > Time: 31s
> > > per
> > > > > > > > second.
> > > > > > > > > PC No3:
> > > > > > > > > Max segments:30ÃÆ'Æ'‚
> > > > > > > > > Time:31s
> > > per
> > > > > > > > second.
> > > > > > > > > Max segments:170
> > > > > > > > > Time:31s
> > > per
> > > > > > > > second.
> > > > > > > > > Max segments:200
> > > > > > > > > Time:31s
> > > per
> > > > > > > > second.
> > > aslo
> > > > > > > > > Max segments:410
> > > > > > > > > Time:31s
> > > per
> > > 7
> > > > > > > > > Fidelizer software only improved performance on pc with ÃÆ'Æ'‚
> > > Win7.
> > > > > > > > > Best regards
> > > > > > > > > > Hi Albert,
> > > 50~150um.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ The
> > > blocksÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ to
> > > more d
> > > GCode.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > 0.4
> > > > > > > > degrees butÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ can't keep up at 0.3 degrees.
> > > in/sec2
> > > > > > > > acceleration.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Here is what I find:
> > > circle
> > > > > > > > generates an N sided Polygon 100 timesÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ with
> > > radius 0.1 inches
> > > gradu
> > > interesting).ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > (see attachment). ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ When using the diagnostic
> > > make sure to set
> > > so t
> > > > > > > > he original segments are used.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ By changing N
> > > (number of sides
> > > with N
> > > > > > > > = 240.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ The total time to do all 100 circles
> > > takes about 30
> > > > > > > > seconds.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ So:
> > > > > > > > per second.
> > > in
> > > the
> > > > > > > > Graphical Display is not aÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ significant factor.
> > > would
> > > > > > > > be significantly different I don't know.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Google
> > > finds some
> > > > > > > > benchmarking tools but they areÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ mainly for High
> > > Speed USB
> > > > > > > > devices like flash drives.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ Some sites state if
> > > an older USB
> > > > > > > > 1.1 device is attached it slows everything down.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > > > Regards
> > > > > > > > > > TKÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚
> > > > > > > > > > Hi Tom,
> > > best
> > > > > > > > for KFlop?
> > > even I
> > > sometimes
> > > installation,
> > > facet
> > > > > > > > > > Break angle 30
> > > > > > > > > > Look ahead 3
> > > > > > > > > > Vel 5
> > > > > > > > > > Best Regards
> > > > > > > > > > Albert Platek
> > > > > > > > > > > Hi Tom,
> > > > > > > > that when I am
> > > > > > > > thats why I
> > > > > > > > > > > Best Regards
> > > > > > > > > > > Albert
> > > PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'‚¦ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡atek
> > > > > > > > > > > > Hi Albert,
> > > 300ipm?
> > > > > > > > > > > > Thanks
> > > > > > > > > > > > TK
> > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > My settings:
> > > > > > > > > > > > Break angle 30
> > > > > > > > > > > > Look ahead 3
> > > overflow
> > > > > > > > almost from
> > > > > > > > > > > > program start)
> > > > > > > > are fairly
> > > > > > > > > > > > smooth)
> > > > > > > > > > > > Vel 5.0
> > > > > > > > > > > > Accel 40
> > > > > > > > arcs, I will
> > > > > > > > > > > > send file tomorrow)
> > > ok
> > > > > > > > (Dell, core 2
> > > > > > > > work, i often
> > > > > > > > Nvidia Gt555)
> > > > > > > > generation slows
> > > > > > > > > > > > Best Regards
> > > > > > > > > > > > Albert PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
> > > wrote:
> > > > > > > > > > > > > Hi Albert,
> > > > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡
> > > settings?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'
> > > > > > > > ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ I don't understand
> > > 1?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ That
> > > > > > > > seems huge.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ Did you
> > > mean 0.001?
> > > > > > > > generating too many
> > > > > > > > > > > > small
> > > segments.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ Are you using the
> > > > > > > > > > > > Smoothing
> > > option?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ That might help make
> > > > > > > > > > > > larger facets.
> > > other.
> > > from
> > > > > > > > the
> > > > > > > > > > > > > TK
> > > > > > > > > > > > > Hi Tom,
> > > > > > > > with same
> > > > > > > > > > > > settings?
> > > is
> > > > > > > > it possible
> > > > > > > > smoothing
> > > > > > > > > > > > > Best Regards
> > > > > > > > > > > > > Albert
> > > PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'†'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
> Sent: Wednesday, February 8, 2012 8:03 AM
Group: DynoMotion Message: 3816 From: albertplatek Date: 2/9/2012
I made test with gamepad conencted to pc, and after 20min I got this
After this I again made test without gamepad and it was working fine.
Gamepad is not important for me, so I will not use it in future.
Best Regards
Albert P³atek
> Hi Tom,
> Best Regards
> Albert P³atek
> > Hi Albert,
> > Hi Tom,
> > Best Regards
> > Albert P³atek
> > > Hi Tom,
> > > again error.
> > > Look Ahead 3 sec
> > > Facet Angle 1.5
> > > *Axis Parameters*
> > > at moment)
> > > Gamepad disabled
> > > Lathe disabled
> > > TAU = 0.010000
> > > ACCEL= 58.677936
> > > ACCEL= 58.927802
> > > ACCEL= 58.960033
> > > ACCEL= 60.769580
> > > ACCEL= 58.512884
> > > ACCEL= 58.924281
> > > ACCEL= 59.024541
> > > ACCEL= 58.133892
> > > ACCEL= 61.956729
> > > ACCEL= 59.006616
> > > ACCEL= 60.105317
> > > ACCEL= 58.828274
> > > ACCEL= 60.622193
> > > ACCEL= 58.060298
> > > ACCEL= 60.837834
> > > ACCEL= 58.185082
> > > ACCEL= 58.925759
> > > ACCEL= 59.444038
> > > ACCEL= 61.017190
> > > ACCEL= 59.082489
> > > ACCEL= 60.176545
> > > ACCEL= 58.677989
> > > ACCEL= 60.129486
> > > ACCEL= 59.890981
> > > ACCEL= 63.703736
> > > ACCEL= 58.300426
> > > ACCEL= 58.390017
> > > ACCEL= 64.994889
> > > ACCEL= 61.344673
> > > ACCEL= 61.264344
> > > ACCEL= 60.206659
> > > ACCEL= 61.110118
> > > ACCEL= 58.861575
> > > ACCEL= 62.844393
> > > ACCEL= 58.712601
> > > ACCEL= 62.743716
> > > ACCEL= 59.412413
> > > ACCEL= 59.090724
> > > ACCEL= 59.607079
> > > ACCEL= 58.240991
> > > ACCEL= 58.200542
> > > ACCEL= 62.400201
> > > ACCEL= 64.401300
> > > ACCEL= 60.829834
> > > ACCEL= 60.765056
> > > ACCEL= 58.584326
> > > ACCEL= 59.368296
> > > ACCEL= 58.845166
> > > ACCEL= 63.692201
> > > ACCEL= 59.398388
> > > ACCEL= 58.492754
> > > ACCEL= 58.201424
> > > ACCEL= 59.713704
> > > ACCEL= 59.488310
> > > ACCEL= 58.663588
> > > ACCEL= 62.887233
> > > ACCEL= 58.256548
> > > ACCEL= 58.483484
> > > ACCEL= 58.042246
> > > ACCEL= 58.518015
> > > ACCEL= 61.312055
> > > ACCEL= 60.224222
> > > ACCEL= 60.041371
> > > ACCEL= 61.019005
> > > ACCEL= 59.857207
> > > ACCEL= 60.667182
> > > ACCEL= 62.517183
> > > ACCEL= 62.978943
> > > ACCEL= 60.672158
> > > ACCEL= 62.764637
> > > ACCEL= 60.755186
> > > ACCEL= 58.177374
> > > ACCEL= 58.144752
> > > ACCEL= 62.349561
> > > ACCEL= 59.094084
> > > ACCEL= 59.707611
> > > ACCEL= 60.042771
> > > ACCEL= 59.493590
> > > ACCEL= 58.381740
> > > ACCEL= 58.552432
> > > ACCEL= 60.385809
> > > ACCEL= 61.290063
> > > ACCEL= 63.347741
> > > ACCEL= 59.724964
> > > ACCEL= 66.035414
> > > ACCEL= 58.827807
> > > ACCEL= 60.704297
> > > ACCEL= 60.619439
> > > ACCEL= 60.255062
> > > ACCEL= 59.246636
> > > ACCEL= 58.966244
> > > ACCEL= 62.119289
> > > ACCEL= 61.110753
> > > ACCEL= 64.018676
> > > ACCEL= 63.911028
> > > ACCEL= 60.811810
> > > ACCEL= 59.177635
> > > ACCEL= 61.196853
> > > ACCEL= 58.680083
> > > ACCEL= 59.527456
> > > ACCEL= 58.087839
> > > ACCEL= 59.119465
> > > ACCEL= 62.853732
> > > ACCEL= 59.093458
> > > ACCEL= 59.161929
> > > ACCEL= 61.429357
> > > ACCEL= 58.803188
> > > ACCEL= 59.175222
> > > ACCEL= 60.219244
> > > ACCEL= 58.596575
> > > ACCEL= 58.764846
> > > ACCEL= 58.426363
> > > ACCEL= 60.086656
> > > ACCEL= 59.610107
> > > ACCEL= 59.229815
> > > ACCEL= 58.044244
> > > ACCEL= 63.695621
> > > ACCEL= 58.131310
> > > ACCEL= 59.107058
> > > ACCEL= 58.927665
> > > ACCEL= 61.165485
> > > ACCEL= 58.315186
> > > ACCEL= 60.871648
> > > ACCEL= 60.176458
> > > ACCEL= 59.214217
> > > ACCEL= 59.208457
> > > ACCEL= 62.621824
> > > ACCEL= 58.398335
> > > ACCEL= 61.152436
> > > ACCEL= 58.604786
> > > ACCEL= 58.729217
> > > ACCEL= 59.923425
> > > ACCEL= 59.677849
> > > ACCEL= 58.123086
> > > ACCEL= 60.433701
> > > ACCEL= 58.291893
> > > ACCEL= 60.252449
> > > ACCEL= 60.417103
> > > ACCEL= 60.433561
> > > ACCEL= 61.127250
> > > ACCEL= 61.402805
> > > ACCEL= 58.202147
> > > ACCEL= 62.299667
> > > ACCEL= 62.973329
> > > ACCEL= 61.678133
> > > ACCEL= 58.407879
> > > ACCEL= 59.317560
> > > ACCEL= 58.968064
> > > ACCEL= 58.048711
> > > ACCEL= 58.288685
> > > ACCEL= 58.241909
> > > ACCEL= 59.930745
> > > ACCEL= 59.450933
> > > ACCEL= 59.439070
> > > ACCEL= 58.143918
> > > ACCEL= 58.259981
> > > ACCEL= 58.482531
> > > ACCEL= 58.101452
> > > ACCEL= 60.411654
> > > ACCEL= 60.631439
> > > ACCEL= 62.469302
> > > ACCEL= 60.847604
> > > ACCEL= 58.350368
> > > *ACCEL= 1166.694794
> > > ACCEL= 450.118253*
> > > ACCEL= 186.931892
> > > ACCEL= 91.714558
> > > ACCEL= 60.190257
> > > ACCEL= 60.530275
> > > ACCEL= 59.028122
> > > Smoothing TAU 0.01
> > > Best Regards
> > > Albert Platek
> > > > Hi Albert,
> > > > then printed those?
> > > > Thanks
> > > > TK
> > > > Hi Tom,
> > > > I use ver 4.28.
> > > > Break Angle 30
> > > > Tau 0.008
> > > > Facet angle 0.5
> > > > Vel 4in/sec
> > > > correct:
> > > > #define channel ch0
> > > > main()
> > > > int k;
> > > > while(1)
> > > > X1 = channel->Dest;
> > > > X2 = channel->Dest;
> > > > X1 = channel->Dest;
> > > > X2 = channel->Dest;
> > > > if(accel>45)
> > > > Here log:
> > > > Best Regards
> > > > Albert P³atek
> > > > wrote:
> > > > > Hi Tom,
> > > > > were stalling.
> > > > > Best Regards
> > > > > Albert P³atek
> > > > wrote:
> > > > > > Hi Tom,
> > > > > > Thank you for help.
> > > > > > Best Regards
> > > > > > Albert Platek
> > > > > > > Hi Albert,
> > > > how
> > > > cause
> > > > but
> > > > incorrect
> > > > email
> > > > don't
> > > > that
> > > > velocity by
> > > > could
> > > > > > > Regards
> > > > > > > TK
> > > > > > > Hi Tom,
> > > > > > > My settings:
> > > > > > > Break angle 30 deg
> > > > > > > Look ahead 3 sec
> > > > > > > Facet angle 1.5 deg
> > > > > > > Tau = 0.008 sec
> > > > > > > bigger reliefs.
> > > > 274000
> > > > with
> > > > didnt
> > > > > > > stall.
> > > > There
> > > > Halts to go
> > > > data,
> > > > discarding
> > > > way in
> > > > annoying
> > > > > > > Best Regards
> > > > > > > Albert P³atek
> > > > > > > > Hi Tom,
> > > > > > > > Thank you.
> > > > > > > > Best regards
> > > > > > > > Albert Platek
> > > > > > > > (a):
> > > > > > > > > Hi Albert,
> > > > USB
> > > > > > > > > Regards
> > > > > > > > > TK
> > > > > > > > > Hi Tom,
> > > > segment
> > > > > > > > > rate.
> > > > > > > > > Btw:
> > > > tested
> > > > > > > > > computer.
> > > > helps.
> > > > > > > > > Controller
> > > > > > > > > 3.0 Host Controller
> > > > no
> > > > > > > > > difference.
> > > > > > > > > Best Regards
> > > > > > > > > Albert Platek
> > > > > > > > > > Hi Albert,
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > seem to
> > > > > > > > > > ÃÆ'Æ'‚
> > > > KFLOP.ÃÆ'Æ'‚ I
> > > > > > > > > > ÃÆ'Æ'‚
> > > > before
> > > > second ti
> > > > which
> > > > of 100x
> > > > changes.ÃÆ'Æ'‚ Iro
> > > > the
> > > > 30
> > > > second
> > > > > > > > > run of a big job.
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Regards
> > > > > > > > > > TK
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Hi Tom,
> > > > > > > > > > PC No1:
> > > > > > > > > > Time: 31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > PC No2:
> > > > > > > > > > Time: 31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > PC No3:
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > Max segments:170
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > Max segments:200
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > aslo
> > > > > > > > > > Max segments:410
> > > > > > > > > > Time:31s
> > > > per
> > > > 7
> > > > Win7.
> > > > > > > > > > Best regards
> > > > > > > > > > > Hi Albert,
> > > > more d
> > > > 0.4
> > > > in/sec2
> > > > circle
> > > > radius 0.1 inches
> > > > gradu
> > > > make sure to set
> > > > so t
> > > > (number of sides
> > > > with N
> > > > takes about 30
> > > > > > > > > per second.
> > > > in
> > > > the
> > > > would
> > > > finds some
> > > > Speed USB
> > > > an older USB
> > > > > > > > > > > Regards
> > > > > > > > > > > Hi Tom,
> > > > best
> > > > > > > > > for KFlop?
> > > > even I
> > > > sometimes
> > > > installation,
> > > > facet
> > > > > > > > > > > Break angle 30
> > > > > > > > > > > Look ahead 3
> > > > > > > > > > > Vel 5
> > > > > > > > > > > Best Regards
> > > > > > > > > > > Albert Platek
> > > > > > > > > > > > Hi Tom,
> > > > > > > > > that when I am
> > > > > > > > > thats why I
> > > > > > > > > > > > Best Regards
> > > > > > > > > > > > Albert
> > > > > > > > > > > > > Hi Albert,
> > > > 300ipm?
> > > > > > > > > > > > > Thanks
> > > > > > > > > > > > > TK
> > > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > > My settings:
> > > > > > > > > > > > > Break angle 30
> > > > > > > > > > > > > Look ahead 3
> > > > overflow
> > > > > > > > > almost from
> > > > > > > > > > > > > program start)
> > > > > > > > > are fairly
> > > > > > > > > > > > > smooth)
> > > > > > > > > > > > > Vel 5.0
> > > > > > > > > > > > > Accel 40
> > > > > > > > > arcs, I will
> > > > > > > > > > > > > send file tomorrow)
> > > > ok
> > > > > > > > > (Dell, core 2
> > > > > > > > > work, i often
> > > > > > > > > Nvidia Gt555)
> > > > > > > > > generation slows
> > > > > > > > > > > > > Best Regards
> > > > wrote:
> > > > > > > > > > > > > > Hi Albert,
> > > > mean 0.001?
> > > > > > > > > generating too many
> > > > > > > > > > > > > small
> > > > > > > > > > > > > Smoothing
> > > > > > > > > > > > > larger facets.
> > > > other.
> > > > from
> > > > > > > > > the
> > > > > > > > > > > > > > Regards
> > > > > > > > > > > > > > TK
> > > > > > > > > > > > > > Hi Tom,
> > > > > > > > > with same
> > > > > > > > > > > > > settings?
> > > > is
> > > > > > > > > it possible
> > > > > > > > > smoothing
> > > > > > > > > > > > > > Best Regards
> > > > > > > > > > > > > > Albert
Group: DynoMotion Message: 3817 From: Tom Kerekes Date: 2/9/2012
Hi Albert,
Thanks for reporting back.  I just wish I understood what was going on.
Group: DynoMotion Message: 3818 From: Brad Murry Date: 2/9/2012
Hello Albert,
You might consider a free trial of http://www.usblyzer.com/download.htm  if you have some extra time on your hands.
I just used it to find a traffic issue and it worked well.
It might show some evidence of USB cross talk or something else weird going on, maybe worth a shot.
-Brad Murry
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of albertplatek
Sent: Thursday, February 09, 2012 12:04 PM
Best Regards
Albert P³atek
> Hi Tom,
> Best Regards
> Albert P³atek
> > Hi Albert,
> > Hi Tom,
> > Best Regards
> > Albert P³atek
> > > Hi Tom,
> > > again error.
> > > Look Ahead 3 sec
> > > Facet Angle 1.5
> > > *Axis Parameters*
> > > at moment)
> > > Gamepad disabled
> > > Lathe disabled
> > > TAU = 0.010000
> > > ACCEL= 58.677936
> > > ACCEL= 58.927802
> > > ACCEL= 58.960033
> > > ACCEL= 60.769580
> > > ACCEL= 58.512884
> > > ACCEL= 58.924281
> > > ACCEL= 59.024541
> > > ACCEL= 58.133892
> > > ACCEL= 61.956729
> > > ACCEL= 59.006616
> > > ACCEL= 60.105317
> > > ACCEL= 58.828274
> > > ACCEL= 60.622193
> > > ACCEL= 58.060298
> > > ACCEL= 60.837834
> > > ACCEL= 58.185082
> > > ACCEL= 58.925759
> > > ACCEL= 59.444038
> > > ACCEL= 61.017190
> > > ACCEL= 59.082489
> > > ACCEL= 60.176545
> > > ACCEL= 58.677989
> > > ACCEL= 60.129486
> > > ACCEL= 59.890981
> > > ACCEL= 63.703736
> > > ACCEL= 58.300426
> > > ACCEL= 58.390017
> > > ACCEL= 64.994889
> > > ACCEL= 61.344673
> > > ACCEL= 61.264344
> > > ACCEL= 60.206659
> > > ACCEL= 61.110118
> > > ACCEL= 58.861575
> > > ACCEL= 62.844393
> > > ACCEL= 58.712601
> > > ACCEL= 62.743716
> > > ACCEL= 59.412413
> > > ACCEL= 59.090724
> > > ACCEL= 59.607079
> > > ACCEL= 58.240991
> > > ACCEL= 58.200542
> > > ACCEL= 62.400201
> > > ACCEL= 64.401300
> > > ACCEL= 60.829834
> > > ACCEL= 60.765056
> > > ACCEL= 58.584326
> > > ACCEL= 59.368296
> > > ACCEL= 58.845166
> > > ACCEL= 63.692201
> > > ACCEL= 59.398388
> > > ACCEL= 58.492754
> > > ACCEL= 58.201424
> > > ACCEL= 59.713704
> > > ACCEL= 59.488310
> > > ACCEL= 58.663588
> > > ACCEL= 62.887233
> > > ACCEL= 58.256548
> > > ACCEL= 58.483484
> > > ACCEL= 58.042246
> > > ACCEL= 58.518015
> > > ACCEL= 61.312055
> > > ACCEL= 60.224222
> > > ACCEL= 60.041371
> > > ACCEL= 61.019005
> > > ACCEL= 59.857207
> > > ACCEL= 60.667182
> > > ACCEL= 62.517183
> > > ACCEL= 62.978943
> > > ACCEL= 60.672158
> > > ACCEL= 62.764637
> > > ACCEL= 60.755186
> > > ACCEL= 58.177374
> > > ACCEL= 58.144752
> > > ACCEL= 62.349561
> > > ACCEL= 59.094084
> > > ACCEL= 59.707611
> > > ACCEL= 60.042771
> > > ACCEL= 59.493590
> > > ACCEL= 58.381740
> > > ACCEL= 58.552432
> > > ACCEL= 60.385809
> > > ACCEL= 61.290063
> > > ACCEL= 63.347741
> > > ACCEL= 59.724964
> > > ACCEL= 66.035414
> > > ACCEL= 58.827807
> > > ACCEL= 60.704297
> > > ACCEL= 60.619439
> > > ACCEL= 60.255062
> > > ACCEL= 59.246636
> > > ACCEL= 58.966244
> > > ACCEL= 62.119289
> > > ACCEL= 61.110753
> > > ACCEL= 64.018676
> > > ACCEL= 63.911028
> > > ACCEL= 60.811810
> > > ACCEL= 59.177635
> > > ACCEL= 61.196853
> > > ACCEL= 58.680083
> > > ACCEL= 59.527456
> > > ACCEL= 58.087839
> > > ACCEL= 59.119465
> > > ACCEL= 62.853732
> > > ACCEL= 59.093458
> > > ACCEL= 59.161929
> > > ACCEL= 61.429357
> > > ACCEL= 58.803188
> > > ACCEL= 59.175222
> > > ACCEL= 60.219244
> > > ACCEL= 58.596575
> > > ACCEL= 58.764846
> > > ACCEL= 58.426363
> > > ACCEL= 60.086656
> > > ACCEL= 59.610107
> > > ACCEL= 59.229815
> > > ACCEL= 58.044244
> > > ACCEL= 63.695621
> > > ACCEL= 58.131310
> > > ACCEL= 59.107058
> > > ACCEL= 58.927665
> > > ACCEL= 61.165485
> > > ACCEL= 58.315186
> > > ACCEL= 60.871648
> > > ACCEL= 60.176458
> > > ACCEL= 59.214217
> > > ACCEL= 59.208457
> > > ACCEL= 62.621824
> > > ACCEL= 58.398335
> > > ACCEL= 61.152436
> > > ACCEL= 58.604786
> > > ACCEL= 58.729217
> > > ACCEL= 59.923425
> > > ACCEL= 59.677849
> > > ACCEL= 58.123086
> > > ACCEL= 60.433701
> > > ACCEL= 58.291893
> > > ACCEL= 60.252449
> > > ACCEL= 60.417103
> > > ACCEL= 60.433561
> > > ACCEL= 61.127250
> > > ACCEL= 61.402805
> > > ACCEL= 58.202147
> > > ACCEL= 62.299667
> > > ACCEL= 62.973329
> > > ACCEL= 61.678133
> > > ACCEL= 58.407879
> > > ACCEL= 59.317560
> > > ACCEL= 58.968064
> > > ACCEL= 58.048711
> > > ACCEL= 58.288685
> > > ACCEL= 58.241909
> > > ACCEL= 59.930745
> > > ACCEL= 59.450933
> > > ACCEL= 59.439070
> > > ACCEL= 58.143918
> > > ACCEL= 58.259981
> > > ACCEL= 58.482531
> > > ACCEL= 58.101452
> > > ACCEL= 60.411654
> > > ACCEL= 60.631439
> > > ACCEL= 62.469302
> > > ACCEL= 60.847604
> > > ACCEL= 58.350368
> > > *ACCEL= 1166.694794
> > > ACCEL= 450.118253*
> > > ACCEL= 186.931892
> > > ACCEL= 91.714558
> > > ACCEL= 60.190257
> > > ACCEL= 60.530275
> > > ACCEL= 59.028122
> > > Smoothing TAU 0.01
> > > Best Regards
> > > Albert Platek
> > > > Hi Albert,
> > > > then printed those?
> > > > Thanks
> > > > TK
> > > > Hi Tom,
> > > > I use ver 4.28.
> > > > Break Angle 30
> > > > Tau 0.008
> > > > Facet angle 0.5
> > > > Vel 4in/sec
> > > > correct:
> > > > #define channel ch0
> > > > main()
> > > > int k;
> > > > while(1)
> > > > X1 = channel->Dest;
> > > > X2 = channel->Dest;
> > > > X1 = channel->Dest;
> > > > X2 = channel->Dest;
> > > > if(accel>45)
> > > > Here log:
> > > > Best Regards
> > > > Albert P³atek
> > > > wrote:
> > > > > Hi Tom,
> > > > > were stalling.
> > > > > Best Regards
> > > > > Albert P³atek
> > > > wrote:
> > > > > > Hi Tom,
> > > > > > Thank you for help.
> > > > > > Best Regards
> > > > > > Albert Platek
> > > > > > > Hi Albert,
> > > > how
> > > > cause
> > > > but
> > > > incorrect
> > > > email
> > > > don't
> > > > that
> > > > velocity by
> > > > could
> > > > > > > Regards
> > > > > > > TK
> > > > > > > Hi Tom,
> > > > > > > My settings:
> > > > > > > Break angle 30 deg
> > > > > > > Look ahead 3 sec
> > > > > > > Facet angle 1.5 deg
> > > > > > > Tau = 0.008 sec
> > > > > > > bigger reliefs.
> > > > 274000
> > > > with
> > > > didnt
> > > > > > > stall.
> > > > There
> > > > Halts to go
> > > > data,
> > > > discarding
> > > > way in
> > > > annoying
> > > > > > > Best Regards
> > > > > > > Albert P³atek
> > > > > > > > Hi Tom,
> > > > > > > > Thank you.
> > > > > > > > Best regards
> > > > > > > > Albert Platek
> > > > > > > > (a):
> > > > > > > > > Hi Albert,
> > > > USB
> > > > > > > > > Regards
> > > > > > > > > TK
> > > > > > > > > Hi Tom,
> > > > segment
> > > > > > > > > rate.
> > > > > > > > > Btw:
> > > > tested
> > > > > > > > > computer.
> > > > helps.
> > > > > > > > > Controller
> > > > > > > > > 3.0 Host Controller
> > > > no
> > > > > > > > > difference.
> > > > > > > > > Best Regards
> > > > > > > > > Albert Platek
> > > > > > > > > > Hi Albert,
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > seem to
> > > > > > > > > > ÃÆ'Æ'‚
> > > > KFLOP.ÃÆ'Æ'‚ I
> > > > > > > > > > ÃÆ'Æ'‚
> > > > before
> > > > second ti
> > > > which
> > > > of 100x
> > > > changes.ÃÆ'Æ'‚ Iro
> > > > the
> > > > 30
> > > > second
> > > > > > > > > run of a big job.
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Regards
> > > > > > > > > > TK
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > ÃÆ'Æ'‚
> > > > > > > > > > Hi Tom,
> > > > > > > > > > PC No1:
> > > > > > > > > > Time: 31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > PC No2:
> > > > > > > > > > Time: 31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > PC No3:
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > Max segments:170
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > > > > > > > Max segments:200
> > > > > > > > > > Time:31s
> > > > per
> > > > > > > > > second.
> > > > aslo
> > > > > > > > > > Max segments:410
> > > > > > > > > > Time:31s
> > > > per
> > > > 7
> > > > Win7.
> > > > > > > > > > Best regards
> > > > > > > > > > > Hi Albert,
> > > > more d
> > > > 0.4
> > > > in/sec2
> > > > circle
> > > > radius 0.1 inches
> > > > gradu
> > > > make sure to set
> > > > so t
> > > > (number of sides
> > > > with N
> > > > takes about 30
> > > > > > > > > per second.
> > > > in
> > > > the
> > > > would
> > > > finds some
> > > > Speed USB
> > > > an older USB
> > > > > > > > > > > Regards
> > > > > > > > > > > Hi Tom,
> > > > best
> > > > > > > > > for KFlop?
> > > > even I
> > > > sometimes
> > > > installation,
(Message over 64 KB, truncated)
Group: DynoMotion Message: 3828 From: albertplatek Date: 2/9/2012
Hi Brad,
Thanks I will try it.
Best Regards
Albert Platek
> Hello Albert,
> -Brad Murry
> Hi Tom,
> Best Regards
> Albert P³atek
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , "albertplatek" <albertplatek86@> wrote:
> > Hi Tom,
> > Best Regards
> > Albert P³atek
> > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , Tom Kerekes <tk@> wrote:
> > > Hi Albert,
> > > Â
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Â
> > > Â
> > > Hi Tom,
> > > Best Regards
> > > Albert P³atek
> > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , Albert P³atek <albertplatek86@> wrote:
> > > > Hi Tom,
> > > > again error.
> > > > Look Ahead 3 sec
> > > > Facet Angle 1.5
> > > > *Axis Parameters*
> > > > at moment)
> > > > Gamepad disabled
> > > > Lathe disabled
> > > > TAU = 0.010000
> > > > ACCEL= 58.677936
> > > > ACCEL= 58.927802
> > > > ACCEL= 58.960033
> > > > ACCEL= 60.769580
> > > > ACCEL= 58.512884
> > > > ACCEL= 58.924281
> > > > ACCEL= 59.024541
> > > > ACCEL= 58.133892
> > > > ACCEL= 61.956729
> > > > ACCEL= 59.006616
> > > > ACCEL= 60.105317
> > > > ACCEL= 58.828274
> > > > ACCEL= 60.622193
> > > > ACCEL= 58.060298
> > > > ACCEL= 60.837834
> > > > ACCEL= 58.185082
> > > > ACCEL= 58.925759
> > > > ACCEL= 59.444038
> > > > ACCEL= 61.017190
> > > > ACCEL= 59.082489
> > > > ACCEL= 60.176545
> > > > ACCEL= 58.677989
> > > > ACCEL= 60.129486
> > > > ACCEL= 59.890981
> > > > ACCEL= 63.703736
> > > > ACCEL= 58.300426
> > > > ACCEL= 58.390017
> > > > ACCEL= 64.994889
> > > > ACCEL= 61.344673
> > > > ACCEL= 61.264344
> > > > ACCEL= 60.206659
> > > > ACCEL= 61.110118
> > > > ACCEL= 58.861575
> > > > ACCEL= 62.844393
> > > > ACCEL= 58.712601
> > > > ACCEL= 62.743716
> > > > ACCEL= 59.412413
> > > > ACCEL= 59.090724
> > > > ACCEL= 59.607079
> > > > ACCEL= 58.240991
> > > > ACCEL= 58.200542
> > > > ACCEL= 62.400201
> > > > ACCEL= 64.401300
> > > > ACCEL= 60.829834
> > > > ACCEL= 60.765056
> > > > ACCEL= 58.584326
> > > > ACCEL= 59.368296
> > > > ACCEL= 58.845166
> > > > ACCEL= 63.692201
> > > > ACCEL= 59.398388
> > > > ACCEL= 58.492754
> > > > ACCEL= 58.201424
> > > > ACCEL= 59.713704
> > > > ACCEL= 59.488310
> > > > ACCEL= 58.663588
> > > > ACCEL= 62.887233
> > > > ACCEL= 58.256548
> > > > ACCEL= 58.483484
> > > > ACCEL= 58.042246
> > > > ACCEL= 58.518015
> > > > ACCEL= 61.312055
> > > > ACCEL= 60.224222
> > > > ACCEL= 60.041371
> > > > ACCEL= 61.019005
> > > > ACCEL= 59.857207
> > > > ACCEL= 60.667182
> > > > ACCEL= 62.517183
> > > > ACCEL= 62.978943
> > > > ACCEL= 60.672158
> > > > ACCEL= 62.764637
> > > > ACCEL= 60.755186
> > > > ACCEL= 58.177374
> > > > ACCEL= 58.144752
> > > > ACCEL= 62.349561
> > > > ACCEL= 59.094084
> > > > ACCEL= 59.707611
> > > > ACCEL= 60.042771
> > > > ACCEL= 59.493590
> > > > ACCEL= 58.381740
> > > > ACCEL= 58.552432
> > > > ACCEL= 60.385809
> > > > ACCEL= 61.290063
> > > > ACCEL= 63.347741
> > > > ACCEL= 59.724964
> > > > ACCEL= 66.035414
> > > > ACCEL= 58.827807
> > > > ACCEL= 60.704297
> > > > ACCEL= 60.619439
> > > > ACCEL= 60.255062
> > > > ACCEL= 59.246636
> > > > ACCEL= 58.966244
> > > > ACCEL= 62.119289
> > > > ACCEL= 61.110753
> > > > ACCEL= 64.018676
> > > > ACCEL= 63.911028
> > > > ACCEL= 60.811810
> > > > ACCEL= 59.177635
> > > > ACCEL= 61.196853
> > > > ACCEL= 58.680083
> > > > ACCEL= 59.527456
> > > > ACCEL= 58.087839
> > > > ACCEL= 59.119465
> > > > ACCEL= 62.853732
> > > > ACCEL= 59.093458
> > > > ACCEL= 59.161929
> > > > ACCEL= 61.429357
> > > > ACCEL= 58.803188
> > > > ACCEL= 59.175222
> > > > ACCEL= 60.219244
> > > > ACCEL= 58.596575
> > > > ACCEL= 58.764846
> > > > ACCEL= 58.426363
> > > > ACCEL= 60.086656
> > > > ACCEL= 59.610107
> > > > ACCEL= 59.229815
> > > > ACCEL= 58.044244
> > > > ACCEL= 63.695621
> > > > ACCEL= 58.131310
> > > > ACCEL= 59.107058
> > > > ACCEL= 58.927665
> > > > ACCEL= 61.165485
> > > > ACCEL= 58.315186
> > > > ACCEL= 60.871648
> > > > ACCEL= 60.176458
> > > > ACCEL= 59.214217
> > > > ACCEL= 59.208457
> > > > ACCEL= 62.621824
> > > > ACCEL= 58.398335
> > > > ACCEL= 61.152436
> > > > ACCEL= 58.604786
> > > > ACCEL= 58.729217
> > > > ACCEL= 59.923425
> > > > ACCEL= 59.677849
> > > > ACCEL= 58.123086
> > > > ACCEL= 60.433701
> > > > ACCEL= 58.291893
> > > > ACCEL= 60.252449
> > > > ACCEL= 60.417103
> > > > ACCEL= 60.433561
> > > > ACCEL= 61.127250
> > > > ACCEL= 61.402805
> > > > ACCEL= 58.202147
> > > > ACCEL= 62.299667
> > > > ACCEL= 62.973329
> > > > ACCEL= 61.678133
> > > > ACCEL= 58.407879
> > > > ACCEL= 59.317560
> > > > ACCEL= 58.968064
> > > > ACCEL= 58.048711
> > > > ACCEL= 58.288685
> > > > ACCEL= 58.241909
> > > > ACCEL= 59.930745
> > > > ACCEL= 59.450933
> > > > ACCEL= 59.439070
> > > > ACCEL= 58.143918
> > > > ACCEL= 58.259981
> > > > ACCEL= 58.482531
> > > > ACCEL= 58.101452
> > > > ACCEL= 60.411654
> > > > ACCEL= 60.631439
> > > > ACCEL= 62.469302
> > > > ACCEL= 60.847604
> > > > ACCEL= 58.350368
> > > > *ACCEL= 1166.694794
> > > > ACCEL= 450.118253*
> > > > ACCEL= 186.931892
> > > > ACCEL= 91.714558
> > > > ACCEL= 60.190257
> > > > ACCEL= 60.530275
> > > > ACCEL= 59.028122
> > > > Smoothing TAU 0.01
> > > > Best Regards
> > > > Albert Platek
> > > > > Hi Albert,
> > > > > then printed those?
> > > > > Thanks
> > > > > TK
> > > > > *To:* DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > > > > Hi Tom,
> > > > > I use ver 4.28.
> > > > > Break Angle 30
> > > > > Tau 0.008
> > > > > Facet angle 0.5
> > > > > Vel 4in/sec
> > > > > correct:
> > > > > #define channel ch0
> > > > > main()
> > > > > int k;
> > > > > while(1)
> > > > > X1 = channel->Dest;
> > > > > X2 = channel->Dest;
> > > > > X1 = channel->Dest;
> > > > > X2 = channel->Dest;
> > > > > if(accel>45)
> > > > > Here log:
> > > > > Best Regards
> > > > > Albert P³atek
> > > > > wrote:
> > > > > > Hi Tom,
> > > > > > were stalling.
> > > > > > Best Regards
> > > > > > Albert P³atek
> > > > > wrote:
> > > > > > > Hi Tom,
> > > > > > > Thank you for help.
> > > > > > > Best Regards
> > > > > > > Albert Platek
> > > > > > > > Hi Albert,
> > > > > how
> > > > > cause
> > > > > but
> > > > > incorrect
> > > > > email
> > > > > don't
> > > > > that
> > > > > velocity by
> > > > > could
> > > > > > > > Regards
> > > > > > > > TK
> > > > > > > > *Subject:* [DynoMotion] Re: Coord buffer overflow again
> > > > > > > > Hi Tom,
> > > > > > > > My settings:
> > > > > > > > Break angle 30 deg
> > > > > > > > Look ahead 3 sec
> > > > > > > > Facet angle 1.5 deg
> > > > > > > > Tau = 0.008 sec
> > > > > > > > bigger reliefs.
> > > > > 274000
> > > > > with
> > > > > didnt
> > > > > > > > stall.
> > > > > There
> > > > > Halts to go
> > > > > data,
> > > > > discarding
> > > > > way in
> > > > > annoying
> > > > > > > > Best Regards
> > > > > > > > Albert PÃÆ'‚³atek
> > > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , Albert <albertplatek86@> wrote:
> > > > > > > > > Hi Tom,
> > > > > > > > > Thank you.
> > > > > > > > > Best regards
> > > > > > > > > Albert Platek
> > > > > > > > > Dnia 2012-01-18 o godz. 23:47 Tom Kerekes <tk@> napisaÃÆ'Æ'…ÃÆ'¢â‚¬Å¡
> > > > > > > > > (a):
> > > > > > > > > > Hi Albert,
> > > > > USB
> > > > > > > > > > Regards
> > > > > > > > > > TK
> > > > > > > > > > From: albertplatek <albertplatek86@>
> > > > > > > > > > To: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > > > > > > > > > Subject: [DynoMotion] Re: Coord buffer overflow again
> > > > > > > > > > Hi Tom,
> > > > > segment
> > > > > > > > > > rate.
> > > > > > > > > > Btw:
> > > > > tested
> > > > > > > > > > computer.
> > > > > helps.
> > > > > > > > > > Controller
> > > > > > > > > > 3.0 Host Controller
> > > > > no
> > > > > > > > > > difference.
> > > > > > > > > > Best Regards
> > > > > > > > > > Albert Platek
> > > > > > > > > > > Hi Albert,
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > seem to
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > KFLOP.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ I
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > before
> > > > > > > > > > .ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ There is an annoying ~30 second delay when it runs the
> > > > > second ti
> > > > > > > > > > me.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ The Interpreter keeps a record of all its state changes
> > > > > which
> > > > > > > > > > allow Halts to go back to any previous state.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ In this test
> > > > > of 100x
> > > > > changes.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Iro
> > > > > the
> > > > > 30
> > > > > > > > > > seconds!ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ We will find a better way in the next
> > > > > version.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ For now
> > > > > > > > > > just don't be surprisedÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ if there is an annoying delay on a
> > > > > second
> > > > > > > > > > run of a big job.
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > Regards
> > > > > > > > > > > TK
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > Hi Tom,
> > > > > > > > > > > PC No1:
> > > > > > > > > > > Max segments: 110ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > Time: 31s
> > > > > per
> > > > > > > > > > second.
> > > > > > > > > > > PC No2:
> > > > > > > > > > > Max segments: 140ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > Time: 31s
> > > > > per
> > > > > > > > > > second.
> > > > > > > > > > > PC No3:
> > > > > > > > > > > Max segments:30ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > Time:31s
> > > > > per
> > > > > > > > > > second.
> > > > > > > > > > > Max segments:170
> > > > > > > > > > > Time:31s
> > > > > per
> > > > > > > > > > second.
> > > > > > > > > > > Max segments:200
> > > > > > > > > > > Time:31s
> > > > > per
> > > > > > > > > > second.
> > > > > aslo
> > > > > > > > > > > Max segments:410
> > > > > > > > > > > Time:31s
> > > > > per
> > > > > 7
> > > > > > > > > > > Fidelizer software only improved performance on pc with ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > Win7.
> > > > > > > > > > > Best regards
> > > > > > > > > > > > Hi Albert,
> > > > > > > > > > > > Your application/system is quite demanding :}
> > > > > > > > > > > > That portion of GCode you sent is 100,000 lines of all G1
> > > > > 50~150um.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ The
> > > > > blocksÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ to
> > > > > > > > > > be combined together so the real required vector rate will be
> > > > > more d
> > > > > GCode.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > > On my system (i7 W7 32-bit) it runs ok with a facet angle 0f
> > > > > 0.4
> > > > > > > > > > degrees butÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ can't keep up at 0.3 degrees.
> > > > > > > > > > > > I did some calculations for a system like yours with 40
> > > > > in/sec2
> > > > > > > > > > acceleration.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Here is what I find:
> > > > > > > > > > > > That acceleration allows going around a 0.1 inch radius
> > > > > circle
> > > > > > > > > > at 120ipm (which is about 3 circles per second)
> > > > > > > > > > > > With a facet angle setting of 1.5 degrees that requires 240
> > > > > > > > > > segments per circle which would require 720 segments per second
> > > > > > > > > > > > I created a diagnostic test GCode file that programmatically
> > > > > > > > > > generates an N sided Polygon 100 timesÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ with
> > > > > radius 0.1 inches
> > > > > > > > > > and allows you to specify the number of polygon sides (it also
> > > > > gradu
> > > > > interesting).ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > (see attachment). ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ When using the diagnostic
> > > > > make sure to set
> > > > > > > > > > the Collinear tolerance to zero and the Corner Rounding to zero
> > > > > so t
> > > > > > > > > > he original segments are used.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ By changing N
> > > > > (number of sides
> > > > > > > > > > we can determine the segment download rate).
> > > > > > > > > > > > For example on my system it works with N = 200 and fails
> > > > > with N
> > > > > > > > > > = 240.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ The total time to do all 100 circles
> > > > > takes about 30
> > > > > > > > > > seconds.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ So:
> > > > > > > > > > > > 100 circles x 200 segments/circle / 30 seconds = 666 segments
> > > > > > > > > > per second.
> > > > > > > > > > > > In simulation mode the Interpreter+Graphics finishes the job
> > > > > in
> > > > > > > > > > ~ 5 seconds so it isn't a significant factor
> > > > > > > > > > > > With the GCode Window closed it simulates in ~ 4 seconds so
> > > > > the
> > > > > > > > > > Graphical Display is not aÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ significant factor.
> > > > > > > > > > > > You might run the tests on your two systems to see if you get
> > > > > > > > > > drastically different results.
> > > > > > > > > > > > But to try to answer your original question of why one CPU
> > > > > would
> > > > > > > > > > be significantly different I don't know.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Google
> > > > > finds some
> > > > > > > > > > benchmarking tools but they areÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ mainly for High
> > > > > Speed USB
> > > > > > > > > > devices like flash drives.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ Some sites state if
> > > > > an older USB
> > > > > > > > > > 1.1 device is attached it slows everything down.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > > TKÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡
> > > > > > > > > > > > From: albertplatek albertplatek86@
> > > > > > > > > > > > Sent: Saturday, January 14, 2012 11:02 AM
> > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > How to determine USB throughput on pc? or what pc/system is
> > > > > best
> > > > > > > > > > for KFlop?
> > > > > > > > > > > > I have still sometimes cord buffer overflow on second pc
> > > > > even I
> > > > > > > > > > > > set lower accelaration 25 and bigger facet angle 2.5 it
> > > > > sometimes
> > > > > > > > > > > > overflow. Its very strange pc has windows xp clean
> > > > > installation,
> > > > > > > > > > > > Integrated Intel Graphics.
> > > > > > > > > > > > On first pc works perfect even with high acceleration 40,
> > > > > facet
> > > > > > > > > > angle 2.0 (also windows xp, but ati graphics)
> > > > > > > > > > > > Break angle 30
> > > > > > > > > > > > Look ahead 3
> > > > > > > > > > > > Corner tolerance 0.005
> > > > > > > > > > > > Vel 5
> > > > > > > > > > > > Best Regards
> > > > > > > > > > > > Albert Platek
> > > > > > > > > > albertplatek86@ wrote:
> > > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > > GCode file is attached with this message.
> > > > > > > > > > > > > Yes feedrate is 300ipm.
> > > > > > > > > > > > > What do you mean by "path generation slows down"? - i mean
> > > > > > > > > > that when I am
> > > > > > > > > > > > > changing view perspective in GViewer
> > > > > > > > > > > > > the "simulated tool" catching up end of buffered path. So
> > > > > > > > > > thats why I
> > > > > > > > > > > > > thought that maybe gviewer impact on performance somehow.
> > > > > > > > > > > > > Best Regards
> > > > > > > > > > > > > Albert
> > > > > PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'‚ÃÆ'‚¦ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡atek
> > > > > > > > > > > > > 2012/1/13 Tom Kerekes tk@
> > > > > > > > > > > > > > Hi Albert,
> > > > > > > > > > > > > > Yes please send the file. Is the feedrate set high
> > > > > 300ipm?
> > > > > > > > > > > > > > Thanks
> > > > > > > > > > > > > > TK
> > > > > > > > > > > > > > *From:* albertplatek albertplatek86@
> > > > > > > > > > > > > > *Sent:* Thursday, January 12, 2012 3:35 PM
> > > > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > > > My settings:
> > > > > > > > > > > > > > Break angle 30
> > > > > > > > > > > > > > Look ahead 3
> > > > > > > > > > > > > > Facet angle 2.0 (if I go to 1.5, i get cord buffer
> > > > > overflow
> > > > > > > > > > almost from
> > > > > > > > > > > > > > program start)
> > > > > > > > > > > > > > I use Tau = 0.01; (with facet angle 2.0 machine movements
> > > > > > > > > > are fairly
> > > > > > > > > > > > > > smooth)
> > > > > > > > > > > > > > All 3 axis has same Vel/Accel parameters:
> > > > > > > > > > > > > > Vel 5.0
> > > > > > > > > > > > > > Accel 40
> > > > > > > > > > > > > > Toolpath is parallel along X-axis (contain a lot of small
> > > > > > > > > > arcs, I will
> > > > > > > > > > > > > > send file tomorrow)
> > > > > > > > > > > > > > With this settings my first router with old laptop works
> > > > > ok
> > > > > > > > > > (Dell, core 2
> > > > > > > > > > > > > > duo, ati graphics card),
> > > > > > > > > > > > > > but on second router (same settings) with new laptop dont
> > > > > > > > > > work, i often
> > > > > > > > > > > > > > get buffer overflows. (laptop Dell, i7 cpu, Win7 64bit,
> > > > > > > > > > Nvidia Gt555)
> > > > > > > > > > > > > > (Btw. when GViewer is open and I move view by mouse path
> > > > > > > > > > generation slows
> > > > > > > > > > > > > > down, is it normal?)
> > > > > > > > > > > > > > Best Regards
> > > > > > > > > > > > > > Albert PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
> > > > > wrote:
> > > > > > > > > > > > > > > Hi Albert,
> > > > > > > > > > > > > > > ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡
> > > > > settings?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'
> > > > > > > > > > ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ I don't understand
> > > > > 1?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ That
> > > > > > > > > > seems huge.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ Did you
> > > > > mean 0.001?
> > > > > > > > > > > > > > > A corner rounding facet angle too small might be
> > > > > > > > > > generating too many
> > > > > > > > > > > > > > small
> > > > > segments.ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ Are you using the
> > > > > > > > > > Coordinated Motion Low Pass Filter
> > > > > > > > > > > > > > Smoothing
> > > > > option?ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ That might help make
> > > > > > > > > > as smooth or smoother motion with
> > > > > > > > > > > > > > larger facets.
> > > > > > > > > > > > > > > The USB throughput can vary from one machine to the
> > > > > other.
> > > > > > > > > > > > > > > No data for the GViewer comes from KFLOP it all comes
> > > > > from
> > > > > > > > > > the
> > > > > > > > > > > > > > trajectory planner on the PC.
> > > > > > > > > > > > > > > Regards
> > > > > > > > > > > > > > > TK
> > > > > > > > > > > > > > > Sent: Thursday, January 12, 2012 11:11 AM
> > > > > > > > > > > > > > > Subject: [DynoMotion] Coord buffer overflow again
> > > > > > > > > > > > > > > Hi Tom,
> > > > > > > > > > > > > > > 1. Why on 1 pc kmotioncnc works ok, but on second not,
> > > > > > > > > > with same
> > > > > > > > > > > > > > settings?
> > > > > > > > > > > > > > > (collinear tollerance 1)
> > > > > > > > > > > > > > > same file, same accelerations etc.
> > > > > > > > > > > > > > > on second I have only usb 3.0 ports.
> > > > > > > > > > > > > > > 2. How much data come to Gviewer from kflop? if a lot
> > > > > is
> > > > > > > > > > it possible
> > > > > > > > > > > > > > > to bypass this if I dont need to use G viewer?
> > > > > > > > > > > > > > > I make a lot of reliefs in wood, with kinda high
> > > > > > > > > > acceleleration 40, if
> > > > > > > > > > > > > > > will be any way to get more performance from kflop with
> > > > > > > > > > smoothing
> > > > > > > > > > > > > > feature will be very good.
> > > > > > > > > > > > > > > Best Regards
> > > > > > > > > > > > > > > Albert
> > > > > PÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'¢â‚¬ 'ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'‚ÃÆ'‚¢ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'‚ÃÆ'‚¬ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Â¦ÃÆ'Æ'‚ÃÆ'‚¡ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'â€Â 'ÃÆ'Æ'Æ'ÃÆ'‚¢ÃÆ'Æ'¢ÃÆ'¢â‚¬Å¡ÃÆ'‚¬ÃÆ'Æ'…ÃÆ'‚¡ÃÆ'Æ'Æ'ÃÆ'†'ÃÆ'Æ'¢ÃÆ'¢â€šÂ¬ÃÆ'…¡ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚³atek
> > > ________________________________
